Question about Uwatec Aladin Prime 3 Gauge Computer Console, Metric SCUBA Equipment
How to set the aladin prime - Uwatec Aladin Prime 3 Gauge Computer Console, Metric SCUBA Equipment
Cancel prime
Email amazon or go to your account settings and cancel there.
Oct 06, 2017 | Amazon Computers & Internet
Is the battery for the Uwatec Aladin Tec 2G 2 Gauge Dive Computer Console - owner changeable?
Unfortunately no it is not. Although it may be possible to do this yourself what the service centre will do is pressure test the unit after battery change to ensure that the computer is still accurate at depth and water tight of course. Hope that helps
Nov 07, 2010 | Uwatec Aladin Tec 2G 2 Gauge Dive Computer...
Extremely short battery life. How to fix?
Battery life is completely dependant on how often you use the computer to dive with. Batteries should generally be changed every two years regardless of use. An authorised dealer will also use the best recommended battery for the unit and not use cheap imported batteries. Hope that helps
Sep 19, 2010 | Uwatec Aladin Tec 2G Wrist Computer SCUBA...
I am looking for a wristband for a uwatec aladin prime dive computer, can't find it!!!!thank you for your time and wish you a good day.
Hello replacement wrist bands are available from any Uwatec stockist (They may have to order it for you) Try speaking to your nearest Scuba store. Hope that helps.
Sep 03, 2010 | Uwatec Aladin Tec 2G Wrist Computer SCUBA...
User manual needed
Bit confused by your question as you cant download a computer!! If your after the software for your Aladin try ebay or order it from any Scuba store that stocks aladin pro computers. Hope that helps.
Feb 20, 2010 | Scuba Diving & Snorkeling
Need parts
its not worth it, a socket 7 mobo takes the original pentium, and they come in varying voltages which has to be adjusted by jumpers. the jumper settings for voltage and cpu mhz will tell you what cpus would be compatible. the ram is doing to be harder to find, it takes old style dram, which is totally obsolete, but can be found as well as a processor on ebay, but its not worth doing.
Apr 13, 2009 | Computers & Internet
Eton webcam 838b
hi
eton drivers
http://www.eton-sa.cn/download.asp
Thanks and good luck.
Ekse
Mar 26, 2009 | Logitech Webcam
I need lexcron aladdin 500k webcam driver
www.thaigoo.com/downloads/drivers/webcam/zc0301pl.zip
IT WORKED FOR ME..is the correct driver for the Aladin Lexcro
Mar 10, 2009 | HP Webcam
Open Questions:
See all Uwatec Aladin Prime 3 Gauge Computer Console, Questions
Uwatec Aladin Prime 3 Gauge Computer Console, Metric SCUBA Equipment Logo
50 people viewed this question
Top Uwatec Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you an Uwatec Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
