Question about Canon PIXMA iP2000 InkJet Printer
Canon Pixima i2000 Warning message "ink absorber almost full" What can be done about this? (There is no info on what to do via the status monitor)
SOURCE: Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Posted on Nov 30, 2007
SOURCE: waste ink tank full
please help me for repair waste in tank full canon ip3300.
Posted on Jan 24, 2008
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
I tried a few times... I have done this alot to many different canon printers. This is what worked for me.
1. Unplug AC (and usb just for good measure)
2. Hold Start while plugging in...
3. While still holding Start press Resume twice.
4. This then allows for Removal of Ink Cartridges(if you are past the limit)... a very important step apparently.
5. Now repeat Step 1... Step 2
6. Now press the Resume 4 times (only blinks for 1st two presses !)
7. Should be ready...
Good luck. I was very happy when this worked for me.
B's
Posted on May 05, 2008
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
Apr 07, 2016 | Canon Office Equipment & Supplies
Canon multipass pixma mp500 waste ink absorber full
printers are cheap buy a new one or look in a dumpster where university students live and have been throwing out junk cuz they are done with school.
Nov 23, 2013 | Canon MultiPASS MP730 All-In-One InkJet...
Error message ink absorber full
Take the printer to a qualified technician, for replacement of the "ink-absorber" unit, and a "reset" of the printer (it has "calculated" when it is full -- unlike the gas-tank in your automobile, there is no actual measurement of the percentage-full status) to indicate that the new absorber is 0% full.
Oct 19, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Absorber is full canon mp145
All ink printers clean the printhead periodically by squirting ink through the nozzles, and collecting it in a sponge type area in the bottom of the unit. In the Canon ink printer, this absorber is monitored, and when it becomes full, it gives you the full message. The printer stops to prevent ink from leaking out of it. (HP has no monitoring system, you know you need service when your desk is ruined)
To replace the ink absorbers on this model, it requires that the printer be dismantled, and a good tech will wash everything, replace the absorbers, and reset the counter.
You have a low end model that can be replaced for what it would cost to do this job.
I don't think it's a job for the do-it-yourselfer.
Sep 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My Canon ip1800 ink absorber is full is there a quick fix
No .You must replace waste ink tank.
to get printout
Jul 01, 2009 | Canon PIXMA iP1300 Printer
The ink absorber is full and printer won't print.
Normally when you get the "ink absorber is full" message, you would take machine to a Canon service center. They will either clean the ink absorbers or more than likely they will replace the ink absorbers. After replacement, the ink absorber full message will have to be reset which is done in the service mode.
Inkworks
866-381-0541
Nov 21, 2008 | Canon PIXMA iP1600 Printer
How to fix it
the ink absorber MUST be emptied on a regular basis. check this link(for drivers) and follow the Canon links to support and then user manual.
Mar 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Waste ink absorber
3.Select "(8) ETC
There you go.
Mar 01, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Oct 19, 2007 | Canon i9100 InkJet Photo Printer
Canon PIXMA iP2000 InkJet Printer Logo
old marine
old marine
