Question about Acer Aspire 1640Z Notebook
Dear sirs when i working with my laptop i recived message tells me that the bad battary and shut down and I'm traying power on but nothing done
    Problem Solver:
  • 10 Answers
Change the battery........
Posted on Aug 02, 2010
Why does the new battray in my packard bell laptop flash and say battray not detected but my laptop works fine
It may be compatibility issue due to voltage or ampere difference. Please replugged after shutting down.
Good Luck
Aug 13, 2012 | HEWLETT-PACKARD G42-415DX Laptop
Sir, my laptop CompaqEvo610C can not charging i check my battary on other same model of Compaq it is working and good condition and give backup more then 1hour. when i put the battary in my laptop again...
Since you tried your battery on another pc, then try a different charge power supply on yours. You may have a bad power supply adapter or your battery terminals on your pc may be dirty and need to be cleaned with rubbing alcohol and a cotton swab.
Sep 29, 2010 | HP Compaq Evo n610c Notebook
When I switch on the laptop it will not run on mains power ,only battery power, however when i shut down the laptop the battery is being charged correctly,
The power options have been changed,when it's on hover over the battary icon down next to the clock,it should say plugged in & charging if not right click on the icon & select power options & then select an option from the menu on the right,go through them all & change them to suit you or create a power plan of your own.
if this doesn't work then it's because the enpowering tech is controling the system so press the green "e" symbol at the top of your keyboard or on your desktop & select the battary icon the settings will be in their or in the settings tab,just have a look around you'll find it.
Sep 28, 2010 | Acer Aspire 5610-4648 Notebook
Sir, I am Hanif.acer aspire 4315, the notbook was dead, when i open bios battary and then power on the notbook, that time worked but keep bios battary and power on that time not working? How to sloved the...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sep 20, 2010 | Acer Aspire 4315 Notebook
C700 laptop's display problem
I have the same issue.
Problem appears only while working with power adapter.
When I turn off power adapter (so notebook is working with battary) everything is OK.
It is somehow connected with shutting down. If disconnect power adapter durring shutting down - next time you will have problems with grey screen.
Don't know how to fix it.
Usually solve by making several reboots and to turning on/off power adapter.
Apr 23, 2010 | Compaq Presario 700 470024-192 Notebook
Notebook fan
Yes most likely as otherwise you would not have been advised to shut down. The processor get red hot is not cooled continuously by the cooler fan. And heat of all sorts is bad for the health of the processor and other components. What I would suggest is to use a Cooling PAD available on Ebay. This is nothing but a tray that has three USB powered fans that keep dissipating the heat with these three fans all the time the laptop is running. Very helpful. Although you spend some money on it, but in the long run it works wonders.
Nov 30, 2009 | Televison & Video
I recive random bad request messages in Google Chrome.
Hey boys. I had the same problem and finally solved it.
Instructions :
1) Go to ProgramFiles
2) Delete the folder named "Relevant Knowledge"
3) Rename the files which can not be deleted.
4) Start Chrome again. It's done :)
Cya..
Apr 06, 2009 | Google Chrome
CLOSE THE INNER COVER
I should have added that the extra plastic insert thing that comes with the CD holder is used when you want to print on the smaller 8cm disks.
Dec 01, 2008 | Canon MP610 Photo All-In-One Printer
My son recently sent me the toshiba satellite laptop he purchased in iraq while serving in the army there because it would no longer boot to windows. i placed the original disk that came with the laptop in...
Try to replace the hdd the laptop probably quit booting into windows because of a bad sector in your hard drive just replace it and you should work fine average cost for a 60gb laptop hdd $60.00
Aug 20, 2008 | Computers & Internet
My Acer Lappy turns off automatically!
This could be a heat issue. Make sure that nothing ( eg dust) is blocking the air vents.
Jan 11, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 1640Z Notebook Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
