I bought dell laptop one month back and now its charger is not working. can u please tell me how to get it replaced or repaired.
  • 32,281 Answers
If your Dell is brand new, then it will be covered by warranty. I suggect you contact Dell for a repair or replacement.
Do not try to fix it because you will most likely void your warranty.
Posted on Aug 02, 2010
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
Dell inspiron battery will not charge
It could actually be the charger. Some chargers do allow the laptop to power on but are not able to charge the battery. Try a replacement charger as it maybe this thats at fault. If this doesnt solve it then the chargeback circuitry on the laptop could be faulty and require repair.
Hope this helps
Leon
Feb 09, 2013 | Dell Inspiron Computers & Internet
Frys chargers
You need a genuine Dell charger not an aftermarket one.
If the problem persists with a genuine Dell charger (and if the laptop is out of warranty, otherwise if it is still in warranty, send it back), the problem lies in a faulty voltage controller on the motherboard. Dismantling the laptop and putting a multimeter across the terminals that exit from the charging port will indicate if you are getting a voltage fluctuation through the charger. Aftermarket chargers especially those bought from the far east are very risky as they are often poorly built and badly insulated. Given the problems you describe, I'd be inclined to take it to a reputable repair shop to be on the safe side. NEVER attempt to dismantle the charger though!
Jun 02, 2012 | Dell Inspiron Laptop 1440
Hello, As i was working on, suddenly my laptop was shut down without any indications. and i tried to start it but it did not. after plugging in the battery charger it started. After that if i remove the...
Looks like you have a faulty battery, since you bought your laptop 4 months ago, I think it is still covered by their warranty. Please try to contact the manufacturer about the possible battery replacement. :)
Some of the things to do/check if the manufacturer requires you to return your laptop to them: 1. Backup all your important files to a different media/storage, like an external hard drive or burn them to blank DVD's
2. You can also tell them that it MIGHT be your charger that's faulty. Either way, they SHOULD check the battery and charger.
Nov 18, 2010 | Acer Computers & Internet
I bought new dell laptop 2 months back in that bluetooth is not working how can i approach dell custermer care and enter button also lost functioning
Please take the computer to the shop from where you bought the laptop and tell them the problem. Since it is within the warranty period they have to do the needful OR get the tel no of the Dell Service Center from them and speak to Dell personally if the the retailer is not taking any responsibility
Aug 29, 2010 | Dell Computers & Internet
Inspiron 1501 charging problem
should find out why the original charger stopped working in the first place... was it a faulty mother board really. anyway if the ratings on the charger you bought are for that laptop indeed, then it should power up the laptop minus the battery. ofcourse if you put in charger minus battery, dont expect it to show the charging led..just try to power it on
Regards
Feb 26, 2010 | Dell Inspiron 1501 Notebook
Charger not recognized
Folks.
The issue with most of the Dell charger issues rekated to a new charger not being able to charge the battery is the fact that Dell has a screwy proprietary circuit design in their laptops and chargers.
It seems that the Dell laptops are designed so
only Dell chargers will work. While other
brands of chargers will power the laptop when plugged in,
they will not charge the battery.
They do this so they have a monopoly on their chargers and thus can charge a frickin' fortune for their, Dell chargers.
Want them to change this? don't buy Dell products for a while. If enough people ban them, they would change this **** overnight!
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Laptop went completely dead
Get in touch with Dell again as the replaced part will be under warranty. You can never tell whether a new or second hand motherboard has been fitted, as manufacturers are able to do either when they repair it, so it just may well of failed again.
Dec 10, 2006 | Dell Inspiron 8500 Notebook
Open Questions:
The smartest way to keep your business files secured on online cloud backup The most secure way to keep your important business data safe online on Cloud backup for easy access anytime anywhere. Apt for businesses of all sizes and also pocket friendly. If you need your life to be sorted out from all the trouble of managing the enormous amount of data that is being generated every day in businesses whether small or large, then look no further because business online backup service of Dataalign is all you need to keep all important data safe and accessible. We at Dataalign provide companies and businesses a unique and easy way to save their essential statistics, facts and information related to different clients securely encrypted on a safe Business Server Data Backup system which allows them to analyze and download their saved data anytime from the saved storage with just a click of the mouse. One of the most distinct and advanced feature of Dataalign Online Cloud Backup is that it makes all your searches easy with the use of artificial intelligence due to which any file or photograph can be accessed by just typing a name or phrase even if you don't remember the particular name of that file. This results from Computer Data Backup smartly and orderly organized documents for easy sorting and categorizing in order of file size, type, owner name, date of creation etc. You never have to worry about the security of your crucially important data on our business as access to all data is restricted only for the person intended. This system provides security and the freedom of choosing who can view all that data. One more feature of this that helps in Business Server Data Backup making our lives more convenient is the choice for the number of days for which you want to keep a data saved on the online storage so that it automatically gets deleted after that, for saving your extra effort of sorting all your data and getting rid of unwanted files and photos to save space for more important data. So, for making your lives less complicated and more sorted contact our toll free helpline number 888 784-9316 for any assistance regarding business online backup.
Aug 18, 2018 | The Computers & Internet
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
