Question about Lexmark Office Equipment & Supplies
Sticking paper Hi we operate a 1 lexmark t 260 printer between 8 people which prints out about 150-250 sheets a hour on a occssions the paper is stuck to together when printed which results in documents getting mislead can you advise on the problem or cause.We use zerox recycle paper. Thanks
  • Lexmark Master
  • 32,281 Answers
Some printers are sensitive to some type/brand of paper. Try a different brand and/or non recycled paper.
Also the way the paper is placed in the paper tray can cause a problem (the paper has a natural curl which is slight and hard to detect). When you open a packet of paper, open it with the wrapping paper edges face up and place the sheets directly into the paper tray this way up, don't turn the paper upside down.
Posted on Aug 02, 2010
  • Lexmark Master
  • 6,826 Answers
Do not use recycled paper in this machine if you can. I would also try to fan the **** of paper before installing it in the machine.
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Lexmark S405 Paper Jam
Hello there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
http://www.printertechs.com/tech/mkinst/mk-1300-5fuser1.php
Feb 10, 2010 | Lexmark All-in-One Printer with PictBridge
My Lexmark C510 printer will print one sheet fine and then give me an error, "201 Paper Jam, Open Rear Door". If I turn the printer off it will reset and I can print one sheet again and will get the same...
there is small Plastic sensor on the paper path, is stucked or broken, is giving this error, need to look closer and check if anything is stucked (paper or dust)
Dec 28, 2009 | Lexmark C510n Laser Printer
Paper stucked inside
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
My Lexmark Z 515 printer does not print clearly especially the second part of a piece of paper. How can I clean the printer?
To improve print quality
1 On the operator panel, press Options repeatedly until
Cartridges appears.
2 Press the right arrow button until Align appears, and then press
Select.
An alignment page prints. Once the alignment sheet prints, your
automatic alignment is complete.
You may need to clean the print cartridge nozzles.
Using the operator panel
Load paper in the All-In-One.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 Try wiping the print cartridge nozzles and contacts, and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
Load plain paper in the All-In-One. 2 Click Start Programs Lexmark X5100 Series Lexmark X5100 Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
6 Print your document again to verify your print quality has improved.
7 Try wiping the print cartridge nozzles and contacts, and then print your document again.
8 If print quality has not improved, try cleaning the print cartridge
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Remove the old cartridges
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print
8 If print quality is still unsatisfactory, replace your print cartridges.
Hope this helps.
Thanks
Have a good day.
Dec 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
Only prints half way and doesn't grab paper right away
Here are the steps:
1.Remove the power cable from the printer.
2.Remove the paper tray from the printer and leave the
paper tray door open.
3.Lightly moisten a lint-free cloth with water.
4.Use the moistened cloth to gently wipe clean the surface
of the roller.
5.Let the feed roller dry before plugging back the AC
power cord
6. Fan the paper to keep the sheets from sticking
together.
7.Place 15 - 20 sheets of paper into the paper tray
8.Insert the paper tray into the printer.
9. Make a print.
If issue persists, call 1.800.235.6325 for repair.
Sep 24, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Std Bin Full
If you see the flag at the paer exit, where the printed paper is.
Jun 18, 2008 | Lexmark Optra T614 Laser Printer
Lexmark e320 thumping on feed
The printer may report load paper when there is enough paper present in the feeder, however this could be due to number of reasons such as if there is something which is blocking the paper to flow through the feeder anything for example, some foreign martial like a pen or a pencil, please find few steps below to fix this issue.
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets are not exciding the required number limit.
5. Adjust the paper feeder guide to the sheet size.
6. Disconnect the printer power cord as well as the printer cable form the printer.
7. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridge and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
8. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
9. Try to rotate the wheel inside the feeder if you can reach it, to ensue that it is free enough to pull the paper.
10. Try printing with having only one sheet in the feeder and check if it does work.
Should you require any further assistance regarding the printer or even any other compute related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 31, 2008 | Lexmark E320 Laser Printer
Paper jamming
Look for some foreign object in the paper path. Easiest way is to turn the printer upside and shake it. (carefully :-)
Aug 31, 2007 | Lexmark X2470 All-In-One InkJet Printer
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
