I have a HP laser jet 1022n printer.i have had it just over a year. When i print it leaves a smudge runnning down the left hand side of the page. i cannot read the firt 2cms of each line. i have replaced the cartridge and still no difference
    Problem Solver:
  • 20 Answers
Sir,
I think theres a problem with the drum of the cartidge try to replace it with a new one. and if still a problem maybe you have to replace the fuser film of the printer.
yours ,
alecz
Posted on Apr 25, 2008
I have a HP Color laser jet 2600n printer. I have tried different Glossy paper, marked for laser jet, but still get bad smudges on my prints. these smudges are still visible on the next ordinary prints...
You need to ensure that you are telling the printer that and your print driver that you are using glossy paper as this will change the speed that the printer prints at and ensure better bonding.
May 23, 2011 | HP Color LaserJet 2600n Printer
Every time I print,the right hand side of the page
Epson inkjet printer or Epson laser printer?
If inkjet, then run the Epson software to "clean" the print-heads.
If laser, then the "fuser" (which uses heat to bond the ink to the paper) is not working -- touch the paper, and see if the left side is warm while the right side is cool.
Nov 01, 2009 | Epson Office Equipment & Supplies
My HP LaserJet 2430n prints black smudge lines down the left side of the page. How can I correct this?
check the fusing unit in the rear of the printer and check your print cartridge for smudges.
Sep 28, 2009 | HP LaserJet 2430dtn Printer
White stripe down left side of page ?
remove the toner cartridge and shake it upside down for couple of minutes vigoursly.and the check the printou.if it prints ok,but if same problem then toner needs refilling as the toner cartridge is empty.or there is powder but due to moisture its got stuck internally.
May 05, 2009 | HP LaserJet 1022 Printer
MY HP LASER JET 2420DN IS gHOSTING DOWN THE LEFT SIDE
The ghosting is most likely the toner or the fuser
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top or front to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the defect on the page the problem is most likely the toner cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 25, 2009 | HP Office Equipment & Supplies
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
New HP 1022n, left half of printed page blank, right half ok
Make sure when you unpacked your printer you took out all the packing styrofoam and small cardboards out of the inside of the printer.
Feb 01, 2009 | HP LaserJet 1022 Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Verticle line down left side of page
Printers tend to have this problem if for some reason dirt gets trapped under the print heads. A standard head cleaning is the best solution, which can be found in the menu.
Mar 18, 2008 | Lexmark X342n All-In-One Laser Printer
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
119 people viewed this question
k24674
jasbo
jasbo
