We have a Onix Air conditioner model GZ 20A E1 does it do heat or only cold air
yalmer
  • 552 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 86 Answers
SOURCE: Code E1 on my Samsung AW1204B Air Conditioner
read manual properly.
may be remote problem
make off airconditioner then after 5 minitue on again
Posted on Mar 17, 2008
SOURCE: reset air conditioner
This did it for me! Same procedure but its described a little more thoroughly here...
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Posted on Jul 21, 2008
  • 143 Answers
SOURCE: AIR CONDITIONER MODEL #AF-S85FX--CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: Have a ge model ASW12ALS1 Air conditioner with error code E1
I have a G.E. window air conditioner that kept giving me the E1 error code and would not allow the unit to turn on. After much frustration (and no results from following various tips on internet forums) I decided that I had nothing to lose by taking the thing apart. After all, it was way past the warranty period.
Make sure the unit is unplugged before doing any of the following.
When I took off the cover (not the front grill, but the metal cover over all the internal parts) I found a small black envelope stuck to the top of the styrofoam inside the unit. What an inconvenient place to find what the error codes mean! It obviously means they don't want the average customer to know any of this. "E1" means a short or open circuit, unit inoperable.
With that in mind I noticed that the black two conductor sensor wire was broken. This is the wire that leads from the sensor on the front fins to the control circuit board. After soldering it back together and wrapping it well with electrical tape the unit works perfectly.
If you don't wish to try soldering the wire, it can be unplugged from the circuit board. I would not be surprised if you can order a new sensor (with wire and plug attached) from a G.E. parts supplier.
By the way, this particular G.E. 6100 BTU air conditioner was manufactured by Samsung electronics.
Posted on Jul 03, 2009
Teach me how to fix aircon says e1?
Hello, Mari-vick -
Without knowing the model number of your Aircon (an air conditioner, I believe), I can only provide you with generic instructions.
I hope you have the owner's manual and have checked there regarding the E1 error code.
If you do not have the manual, then . . .
Reasons for E1 error code, air conditioner:
1. Clean or replace the air filter. Note: Unplug the unit first. After cleaning or air filter replacement, plug the unit back in to the electrical outlet.
2. If the E1 error code still displays, it could mean one of the following problems:
- loose internal connections
- indoor and outdoor parts communications problem
- faulty control panel
Note: You may need an Aircon authorized repair technician for any such repairs.
Read more about the E1 error code on air conditioners and what may be malfunctioning here:
https://www.hunker.com/13407286/how-to-fix-an-air-conditioner-when-it-gives-you-an-e1-code
Best wishes.
May 08, 2018 | Heating & Cooling
My air conditioner showing on the display is E1
The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
How to Fix an Air Conditioner When It Gives You an E1 Code eHow
Jan 24, 2016 | Heating & Cooling
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
RETAIL PRICE FOR ONIX REVERSE CYCLE SPLIT SYSTEM
contact shops that install units and get quotes. retailers generally have contractors that will give quotes for installation on new units.
Jan 01, 2015 | Heating & Cooling
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
Owner manual onix evaporative cooler
The Onix (Sold at Coles) is identical to the Home Maker FSH-90R (Sold at K-Mart). You can download the Home Maker FSH-90R/Onix user manual at the address below; just search for FSH-90R in the manuals section option under cooling products.
http://www.tempoaustralia.com.au/onix-products/cooling/evaporative-air-cooler
Direct PDF link as of May 2013:
http://www.tempoaustralia.com.au/manuals/onix//Cooling/FSH-90R.pdf
Hope this helps.
Nov 14, 2011 | Heating & Cooling
My elderly father has an older model Heller Air Con - code is GZ-1002B-EY We are able to get the cold air flowing but it will not go to hot air - what could be the problem ???
This might be a couple things M's Jackie. 1 the reversing valve is stuck or bad,2 the swtch is broken , Is this a heat pump. Meaning you use it to both heat and cool the home? There is not gas connected to this unit?
Jul 14, 2011 | Heating & Cooling
E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Jul 26, 2008 | Danby DAC8003D Air Conditioner
Heating & Cooling Logo
217 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
