Since I don't
have the manual, Could you please tell me the process for taking it out of P-scan. Thanks so much, Paula Gunnell
My Memorex DVD player is stuck on PScan. Right now the picture shows twice on the same screen. One half of the screen shows the same picture as the second half of the screen. The words PScan is in black sitting right in a yellow shape in the middle of the whole screen. I just want one picture to show up on the television screen. Can you please help me straighten this out?
Thanks, had the same problem and found the switch!
AnonymousAug 10, 2008
my dvd player is also stuckmy dvd player is also stuck
AnonymousDec 28, 2008
Picture on Screen is split and the word PSCAN is in middle in yellow letters.Picture on Screen is split and the word PSCAN is in middle in yellow letters.
You can't post conmments that contain an email address.
Most DVD players has a P-Scan on/off button in the remote control. On the other hand, Memorex in some of its models have the P Scan switch at the rear of the unit. It is a slide switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
The first thing that you must do is make sure that the device is already installed to your computer. Insert the document to be scanned on the scanner. Double click the icon of your scanner and on the option menu click scan. After the scanning process, open the My Picture folder of your computer and locate the image file.
Thanks for choosing FixYa and welcome to the site. The check engine light comes on when the computer in your car detects a problem with the vehicle. You can take it to Autozone or Advanced and have them scan it to find out what is wrong. You have to get the scan because there are over a hundred things that can turn it on. The scan will tell you exactly what to change so you are not guessing or throwing money on parts you don't need. It only takes them a minute to perform the test. It could be fuel issues, ignition issues, transmission issues, or bad information sensors. The scan will tell you your next move. If you need help then, just let me know and I will help. Best wishes.
Are you getting that message from Windws scan? If it is then, that is a fake hard drive analysis and optimization program so you need to remove it from your computer. by following these steps: If you're not familiar in dealing with the registry, please install malwarebytes from http://www.malwarebytes.org/
Manual Removal: 1. Press Ctrl+Alt+Del on keyboard to stop process associated to "Windows Scan". When Windows Task Manager opens, go to Processes Tab and find and end the following process: (random characters).exe
2. You need to update your installed antivirus application to have the latest database. 3. Thoroughly scan the computer and any detected threats must be removed. If removal is prohibited, it is best to quarantine the infected item. Manually locating and deleting of malicious files should also be performed. Please see files below that are related to Windows Scan Virus. 4. Registry entries created by Windows Scan must also be remove from the Windows system. Please refer below for entries associated to the rogue program. [how to edit registry] 5. Exit registry editor. 6. Get rid of Windows Scan start-up entry by going to Start > Run, type msconfig on the "Open" dialog box. A windows containing System Configuration Utility will be launched. Go to Startup tab and uncheck the following Start-up item(s): (random characters).exe
you need to scan for codes
codes will tell you what has malfuntion
you can buy a scanner or take to a garage to scan
some parts store will scan and retrive codes and make suggestion
based on previous sales what may be wrong
your car your call
Try to turn off unit and remove battery pack, then reinstall it after 10 mins and while its off press scan button for 5 seconds and turn it back on. it should automatically go to scan mode on WX
I believe you must select a different application to use for the Scan. Click the cancel From the ALL-IN-ONE center scanning and copying tab, choose a different application from the "SEND SCANNED IMAGE TO" menu.
ok...can you scan from the front panel controls, at all? Is this a computer manager fault? Let's isolate this, shall we? you should be able to scan from buttons on front, by placing a doc on the glass, and pressing scan..
