Question about AEG Lavamat 72640 Front Load Washer
E30 Error code E30 is appearing. What is this?
    Genius:
  • 1,417 Answers
what this indicate simple mean that there has been an over flow of water into the panel(that is power control ) or there has been a loos of wire from the connection of the panel connected to one of the button .
what you are to do to fix up this problem is to unscrew (open) the washer from the stroll then clean up the the panel very well with out disconnecting any wire from it position or
from the loos of wire trace the wire down to the control button connected to the panel and fix up the loos wire back to is position (on the control button)
please this with care with out any form of this connection on the wires.
thank you.
Posted on Aug 02, 2010
3 Suggested Answers
SOURCE: aeg 74640 error code e30
What does the E40 error code mean?
Posted on Sep 18, 2008
  • 135 Answers
SOURCE: error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Posted on Jan 18, 2009
Canon irc2100
Sir, there doesn't seem to be an error code accounted for that reads E30.
Canon IRC 2100 Service Repair Manual
That is the link to the service repair manual which also has the error codes so you can diagnose what is going on although there doesn't seem to be an E30 code accounted for.
This is a more extended list of all of the error codes and once again there seems to be no E30. There are 9 pages of error codes if you'd like to look.
Error Codes Canon iRC2100 page 1
Perhaps a mistype?
Aug 30, 2014 | Canon iR 2016i Black and White Copier
Electrolux washing machine error code e30
Hello sreenivasulu, if you are receiving error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
Jul 25, 2013 | Electrolux Washing Machines
Error code e30 see user guide .comes on and stops washing do not have user guide
Jan 18, 2009 | Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Aeg 74640 error code e30
Jul 09, 2008 | AEG Lavamat 74640 Front Load Washer
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
AEG Lavamat 72640 Front Load Washer Logo
516 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
