Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Usb i cannot open my usb anymore it says in the dialog box that i already consumed already the 2 gig
    President:
  • 1,944 Answers
Try to back up all important data and reformat the drive.
Posted on Apr 25, 2008
How to repair nokia 7310c contact service problem
There might be a hardware problem but as well it could be just software related. Try reinstalling the device firmware.
***Prerequsite:
Install Nokia PC Suite for your phone and the drivers if you haven't already done that!
First of all, you'll need a program and the necessary firmware files:
1. Phoenix Service Suite (2012 or any other version. Search for it on Google)
2. Nokia 7310c firmware (RM 379 DP20 3 00 sw 09 40 7310c)
Install Phoenix Service Suite, extract the software (it will auto-extract the necessary files in the right folder, but first it is necessary to install Phoenix).
Now, after staring Phoenix, do the following:
1. Click File > Open product (not Open profile!)
2. Select RM-379 from the list (you can type that in the "Type filter" text box to find it faster)
3. Select the product code (RM-379) from the list and press OK
4. Now press Flashing (at the top menu, where is also File)
5. Check Dead phone USB flashing on the new dialog box that appears.
6. Click the browse button at the Product code input (top section of the new dialog box)
7. Select an option. Any will do. The difference is between regions and languages. But since I don't know from where are you or what language you'll need on your phone, I can't tell you exactly what to choose. But all region files have "English" avaible
8. Press Refurbish. Take out the phone battery, insert the USB cable, then insert the battery. If any dialog pops up, press OK.
8* At this point, DO NOT DISCONNECT THE USB CABLE until the process is finished!
This process should take about 5-10 minutes and after it is finished, the phone should boot up by itself and everything will be fine.
May 29, 2014 | Nokia 7310 Cellular Phone
WE HAVE A READY 2 DOWNLOAD MESSAGE ON OUR SCREEN AND WE CANNOT GET RID OF IT. WE TRIED SHUTTING IT OFF .
This is the current solution posted by HP. Sounds like your firmware is corrupt and these are the steps you need to take. This may or may not work.
  1. Close the firmware update tool on the computer if it is still active on the screen, and then turn off the product.
  2. If the product is on a network, connect a USB cable (2 meters or less) from the product to an open port on the computer. HP recommends that this be a direct connection instead of through a hub.
  3. Turn on the product, and then wait for the message ready 2 Download to appear.
  4. On the computer, cancel any alerts about a new device being connected.
  5. On the computer, open the Printers and Faxes control panel.
  6. Right-click the printer driver for the product model that is being updated, and then click Properties .
  7. In the Properties dialog box, click the Ports tab.
  8. Note the name of the port that the product is currently connected to for use later when reconnecting at the end of this process.
  9. Click the check box next to USB001 . If USB001 is already connected to another USB device, click USBXXX where "XXX" is the highest-numbered USB device that has a description of Virtual printer port for USB . Using the scroll bars on the right side of the window might be necessary, depending on the number of devices installed.
  10. Click OK to accept the change and apply the settings.
  11. Restart the firmware update tool on the computer, and then select the same product that was just created.
  12. Start the firmware download.
  13. Verify that the control panel display shows Erasing and then Programming , indicating that the update process has begun. Do not interrupt the firmware update process.
  14. The product should momentarily show the message Complete . Turn the product off and then back on. The product will not automatically reboot.
  15. When the product reboots, on the computer, cancel any alerts about a new device being connected.
  16. Print a configuration page to verify that the update occurred.
  17. Return to the Printers and Faxes dialog box, right-click the printer driver for the product model that is being updated, and then click Properties .
  18. In the Properties dialog box, click the Ports tab.
  19. Click the check box next to the previous port to which the product was connected before the update began.
  20. Click OK to accept the change and apply the settings.
  21. If the product was previously connected via USB, the process is complete. If the product was network-connected, disconnect the USB cable, and then reconnect the product to the network cable.
Apr 19, 2011 | HP Laserjet CM2320nf All-In-One Color...
Links dont open in my Outlook 2007, why?
  1. Click Start, and then click My Computer.
  2. On the Tools menu, click Folder Options.
  3. In the Folder Options dialog box, click the File Types tab.
  4. In the Registered file types list, click (NONE) URL:HyperText Transfer Protocol, and then click Advanced.
  5. In the Edit File Type dialog box, click Edit.
    Important Make sure that you note the current values for the fields that are in this dialog box before you go to the next step. You may have to restore the values for the fields that you changed if this method does not resolve the issue.
  6. In the Action box, type open if it is not already there.
  7. In the Application used to perform action box, type "C:\Program Files\Internet Explorer\iexplore.exe" -nohome if it is not already there.
  8. Click to select the Use DDE check box if it is not already selected.
  9. In the DDE Message box, type "%1",,-1,0,,,, if it is not already there.
  10. In the Application box, type IExplore if it is not already there.
  11. Make sure that there is no value in the DDE Application Not Running box. If there is a value in this box, delete it.
  12. In the Topic box, type WWW_OpenURL if it is not already there.
  13. To close the Edit File Type dialog box, click OK two times.
  14. In the Registered file types list, locate and click (NONE) URL:HyperText Transfer Protocol with Privacy, and then click Advanced.
  15. Repeat steps 5 through 14 by using the (NONE) URL:HyperText Transfer Protocol with Privacy list item instead of the (NONE) URL:HyperText Transfer Protocol list item.
  16. To close the Folder Options dialog box, click OK.
  17. Test a hyperlink from Outlook Express.
hope this helpful
Jan 08, 2011 | Microsoft Office Professional 2007 Full...
My printer is stuck in "Ready 2 download" mode.
You get that error when you are trying to upload the firmware and the printer power was interrupted.
1. Close the firmware update tool on the computer if it is still active on the screen, and then turn off the product. 2. If the product is on a network, connect a USB cable (2 meters or less) from the product to an open port on the computer. HP recommends that this be a direct connection instead of through a hub. 3. Turn on the product, and then wait for the message ready 2 Download to appear. 4. On the computer, cancel any alerts about a new device being connected. 5. On the computer, open the Printers and Faxes control panel. 6. Right-click the printer driver for the product model that is being updated, and then click Properties. 7. In the Properties dialog box, click the Ports tab. 8. Note the name of the port that the product is currently connected to for use later when reconnecting at the end of this process. 9. Click the check box next to USB001. If USB001 is already connected to another USB device, click USBXXX where "XXX" is the highest-numbered USB device that has a description of "Virtual printer port for USB". Using the scroll bars on the right side of the window might be necessary, depending on the number of devices installed. 10. Click OK to accept the change and apply the settings. 11. Restart the firmware update tool on the computer, and then select the same product that was just created. 12. Start the firmware download. 13. Verify that the control panel display shows Erasing and then Programming, indicating that the update process has begun. Do not interrupt the firmware update process. 14. The product should momentarily show the message Complete. Turn the product off and then back on. The product will not automatically reboot. 15. When the product reboots, on the computer, cancel any alerts about a new device being connected. 16. Print a configuration page to verify that the update occurred. 17. Return to the Printers and Faxes dialog box, right-click the printer driver for the product model that
is being updated, and then click Properties 18. In the Properties dialog box, click the Ports tab. 19. Click the check box next to the previous port to which the product was connected before the update began.
Nov 07, 2010 | HP LaserJet CM1312 All-In-One Printer
My hp photosmart c3140 all-in-one printer wont scan or copy anymore. I have done all the troubleshooting that I can think of. any suggestions?
The HP Scan Diagnostic Utility might not be available for all HP products, particularly older products. It is available for most products, however, and in most languages.
  • Right-click the following link, and then click Open in New Window . Link to tool (right-click) File size c02222410.gif HP Scan Diagnostic Utility 2.23M
  • Make sure your computer meets the system requirements, and then click Download .
  • When the Security Warning dialog box opens, click Save . The Save As dialog box opens. c01733891.gif Important: HP recommends that you save the download according to the following directions to ensure that you can easily access the tool again at a later time.
  • Click Desktop , and then click Save . The Scan Diagnostic Utility is now saved to your desktop so that you can access it any time.
  • When the Download Complete dialog box opens, click Run , and then click Run again on the Security Warning dialog box.
  • When the tool finishes installing, click Finish . The Scan Diagnostic Utility opens automatically with a list of installed products.
    Oct 28, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
    Which is the scan button mp520 canon printer
    Easy Scanning with One-click You can complete from scanning to saving easily by simply clicking the corresponding icon.
    1. Place the document face-down on the platen.
    2. On the Windows desktop, double-click (MP Navigator EX 1.0).
    Alternatively, on the Windows taskbar, click Start, point to (All) Programs, Canon Utilities, then MP Navigator EX 1.0. Then click MP Navigator EX 1.0.
    The MP Navigator EX navigation mode screen or one-click mode screen opens.
    3. Point to One-click.
    4. Click the corresponding icon.
    Save to PC
    Scan documents or photographs and save them to a computer.
    The Save dialog box opens when you click this button. Specify the scan/save settings and scan.
    Save as PDF file
    Scan documents, save them as PDF files and start the specified application.
    The PDF dialog box opens when you click this button. Specify the scan/save settings and scan.
    Attach to E-mail
    Scan documents or photographs and attach them to e-mail.
    The Mail dialog box opens when you click this button. Specify the save settings and e-mail software program, and scan.
    OCR
    Scan text documents and open them in OmniPage SE by default.
    The OCR dialog box opens when you click this button. Specify the save settings and application, and scan.
    May 18, 2010 | Canon MP520 All-In-One InkJet Photo...
    Cannot Scan, already tried unlugging power/USB (blue light is on)
    I'm going through the same problem. You will have to uninstall all of the software and go over each step to reinstall it. Follow them exactly. If you do step 4 before step 3, you could end up in this situation. Make sure the Scansnap isnt plugged in while you're reinstalling it.
    Also, try other USB ports.
    Mar 20, 2009 | Fujitsu ScanSnap S510
    How to close dialog box to open microsoft word office
    im having the same problem!!!! im trying to finish my paper for my geograhy class. but theres a pop up that wont let me for to my work tht i've already done...its telling me to vlivk ok, and then close open dialoge boxes to continue! WHAT DO I DO?????
    Jan 05, 2009 | Microsoft Office Word 2003 for PC
    Verbatim 1 Gig jump drive doesnt power up when plugged into the USB port anymore,thus preventing files from opening up.
    It may be a bad jump drive or your usb port is broken. Try pluggging it into a differnt USB port
    Aug 06, 2008 | Computers & Internet
    I am trying to download a program from a link and it wont run
    When you click on the link again and then click the Save button, a dialog box opens that indicates the folder to which it will/already did save to. To figure out where exactly that location is, when the dialog box is open you should see across the top the path to that folder. Another option, is when that dialog box is open, you can then change it to your Desktop and save it again there. That should be pretty easy to find.
    Feb 06, 2008 | Microsoft Windows Vista Ultimate Edition
    SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
    Top SanDisk Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    CiNi
    Sandy Moore
    Sandy Moore
    Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
