Question about Samsung SyncMaster 931B 19" LCD Monitor
One single dot it showing in my monitor of lcd
  • 214 Answers
Its damaged
Posted on Aug 02, 2010
I have (suddenly) a single dotted black line about a quarter wasy down my screen on laptop. Can I get rid of it?
First, you need to verify if the dot is cause by faulty graphics chip/card or LCD/LED. To do this use external monitor, if you cant see dot on your external monitor then you have faulty LCD/LED if you see dot like in your laptop the you have graphics chip/card problem.
Oct 09, 2014 | Acer Computers & Internet
Acer monitor screen showing partial screen only. rest of screen showing black & white dots.
Hello there.
Try the monitor with ANOTHER computer,
This will prove whether it is the Monitor at fault or not.
Sep 25, 2014 | Computers & Internet
Pace tech cardiac monitor Fault when power is they LCD show colour line after few second dot blinking on the screen and still same
Bad caps on the internal power supply. Open the LCD and check / replace the bad caps. Fix should be under 20 bucks
Mar 25, 2014 | Computers & Internet
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
When I connect the lcd to my laptop, the lad shows
hi atuire,
try hooking up the lcd screen toanother computer and if it shows the same double screen again then there is aomething wrong with your lcd monitor,
you may want to use another monitor with your laptop to ensure the problem is not on the laptop's side.
if issue stays same with another monitor, then just right-click onto desktop background, goto properties and have a look whether you have enabled the shared monitor feature
(meaning that u can use two screens with just one graphics card parallel, to work on a 'wider' range of sight.
Therefore your machine's graphics card sually must be equipped with both: a standard vga out and a HDMI-out as well.)
if your machine ddoes not have these capabilities but still the monitor sharing is turned on from the software side, this might cause the problem. To disable simply change the graphics card's
propertiers as descried above.
Good luck
Sep 06, 2009 | Gateway Computers & Internet
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
May 03, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
HP 1740 LCD Monitor, showing 4 blue dots on screen
Does the rest of the picture come in okay? Just 4 small dots? Those are probably dead pixels. I believe you have to have 5 (in most cases) to claim it as defective. Some people have had success tapping on them (be gentle) otherwise, you can send it into a repair company.
Dec 08, 2008 | HP Pavilion F1703 17" LCD Monitor
Monitor showing dots all over
Dear user,
It could be the following 4 errors:
1, Vga cable damaged.
2, Video card memory failure.
3, Lcd Panel starterd to damage.
4, The connection between the computer and the monitor is not stable, the plug is not tighten on a side it could be any sideo on the vga cable meaning you have not screwed into the monitor it can lease and fall down from the monitor.
Please check thease.
Nov 17, 2008 | Kogi L7CH Monitor
Lcd problem white pin dot on screen
Probaly will not get worse, but is a stuck pixel. If you press on the screen at that pixel, does it go away? Check with mfr see if it is covered.
Jun 05, 2008 | Dell E173FP 17" LCD Monitor
Samsung SyncMaster 931B 19" LCD Monitor Logo
44 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
