Question about Hotpoint Washing Machines
Symbols on a hotpoint WD23 washing machine
What does the symbols on a hotpoint WD23 washing machine mean
    Genius:
  • 1,417 Answers
what this indicate is that window / door are not properly close to there position that is free ton air at 23 degree
please make sure that doors are properly close before use and also there should be no over flow of water on the panel that is control unit .
thank you.
Posted on Aug 02, 2010
Hello,how do i unlock child lock from a hotpoint washing machine WDUD 9640 .I hold button mor times dosent work.switch off and on doset work I need a help please
Check page 6:
http://docs.hotpoint.eu/_doc/19509812000_GB.pdf
CHILD LOCK button:
to activate the control panel lock,
press and hold the button for approximately 2 seconds.
When the symbol CHILD LOCK is illuminated,
the control panel is locked.
This means it is possible to prevent wash
cycles from being modified accidentally,
especially where there are children in the home.
To deactivate the control panel lock,
Feb 04, 2018 | Hotpoint Washing Machines
H20 symbol on display of hotpoint wf 860 washing machine
Pull off your washer mains cord from the wall. Turn off your wall faucet,, the valve on wall which allows water into the washer. (h2o means your washer is not receiving the most importing thing - water). Disconnect the pipes of the water from the wall. Check by opening the wall valve to see if the water flow is gud. Next fit back carefully. Then unscrew the other end of the hose/hoses at the entry point of your washer - remove the fine filters and clean out with an old tooth brush; clean inside the opening of inlet valve too carefully, check. Now re-fit the filters carefully and screw back the hoses. You are done now. It is advisable to close the wall valve when your washing is done, takes pressure off the machine valve.
Pl click if helped.....
Apr 05, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf840 not starting
Machine may not be finding the signal from the door interlock, check the wire connections to it.
Dec 29, 2012 | Hotpoint Ultima WF860 Front Load Washer
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
My hotpoint aquarius wf250 won't do anything it lights up with wash symbol but doesn't fill or wash it doesn't make no noise or anything please help
open the top of washing machine and near the door on right side is a connector loose just push in and will work fine.
May 10, 2009 | Washing Machines
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
WMA61 Hotpoint Washing Machine 'Red Tap' symbol is flashing
well if your sure the other end is connected to the tub and is tight then id replace the switch its out of calibration it works off positive pressure from the water in the tub if you can blow in it and it actuates doesn't mean its working off the right pressure from the tub
Jan 27, 2008 | Hotpoint WMA76 Front Load Washer
Washing Machine
Which symbol is illuminated? Red keyhole? Child safety? Red tap? End status?
Jun 27, 2007 | Hotpoint WMA76 Front Load Washer
Washing Machines Logo
331 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
