Question about LG LN740 GPS
I delet the softwear from memoreyc ard on lg ln 700 so i want load it back . i did but when i reset from side bottom it dosent show any thing
Door latch wont unlock LG WM2455 Front Load Washer
You can also gain access from the back by removing the back panel...The top on this washer can also be removed..Remove the dispenser cover...Take a putty knife..Insert it in between the top cover and the cabinet ..Push in the tabs located 4 inches in from the sides.
Oct 20, 2012 | LG WM2455 Front Load Washer
How can i reset phon privacy passward of samsung sghl-700 to default
try to reset the phone using the code *2767*3855#......it automatically gets reboot.
but the thing is ur phone gets reset so ur phonenumbers, msgs, images, videosetc saved in the phone memory will be deleted....so better take a back of phone memory and the go 4 the reset....
Nov 11, 2011 | Samsung SGH Cell Phones
Ipad screen goes gray
Press round button twice , icon bar should come up on bottom row , press safari icon and it should shake with delete red circle on it . Press delete . Then turn off and turn back on . Usually means screen in safari jamed in a operation. This process dosent delete it of your machine it just resets it.
Nov 09, 2011 | Apple safari
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
Jun 13, 2009 | Datel Action Replay for Nintendo DS
Action Replay DS has deleted avery single cheat code it came with
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
  1. With your console powered off insert the Action Replay DS
  2. Hold down buttons A+B
  3. Turn your console on
  4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
  5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
  6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
source codejunkies
May 13, 2009 | Datel Action Replay for Nintendo DS
Lg EnV VX9900 CLR Button Resets phone.
When you hit the clr button it will go back to the screen you where prior. When your booting up, it will show the Vcast screen. Maybe check your backlight setting.
Jan 17, 2009 | LG enV VX9900 Cellular Phone
Magellan 700 sound problem
1. Search for the file ENG_F.SND sound on google or yahoo or any search engine.
2. Connect RM 700 to PC, and create folder name SOUND_EU on RM 700.
3. Copy the ENG_F.SND to SOUND_EU folder.
4. Disconnect RM 700 from PC.
5. Turn on RM 700, and go to Option, configuration, language, and choose English.
6. RM 700 will load sound file and turn off.
7. Turn on RM 700, if it keeps showing the initial screen, then connect the RM 700 to PC, and DELETE the ENG_F.SND from SOUND_EU. It should be OK after you disconnect RM 700 from PC and turn it on again.
GOOD LUCK!
NOTES: My screen indeed locked at first as covered in the last step, so expect that to happen. Don't worry if you never get to do step 5 and 6. Connecting the USB, deleting the SND file and restarting it works and the sound is back even without the file there.
This only fixes the Female voice along with the beeps and clicks. The unit goes silent again if you select the male voice but switching back to the female fixed that. I assume "_F" in the file name must mean female.
Aug 18, 2008 | Magellan RoadMate 700 GPS Receiver
Media ard reader being write protected
First try to see is there is any lock in your card reader or adapter and see if its not locking the media..it looks like slide switch .for one end it will lock the media and when you switch to other side you have the full access
but if that's not the reason it might be the problem with registry
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Apr 06, 2008 | iLO MP3 Player
Tomtom 700 will not fully load
On the bottom of the TomTom there is a tiny hole that you stick a small paper clip into. This is a reset button. Its almost not visable you really have to look for it. I have the same problem but I hit the reset and it fixed the problem. This reset won't change or hurt any of your settings it just resets the hard drive.
Feb 13, 2008 | Tomtom GO 700 GPS Receiver
LG LN740 GPS Logo
24 people viewed this question
Top LG GPS Experts
Marvin
Marvin
Rochell Cruz
Are you a LG GPS Expert? Answer questions, earn points and help others
