Floowing this erro i will have modify the Registery Editor in the Following Location :
Expand HKEY_LOCAL_MACHINE.
Click down the key path:
"System\CurrentControlSet\Services\NtFrs\Parameters"
Double click on the value name
"Enable Journal Wrap Automatic Restore"
and update the value.
After this the regedit create automaticaly the Current set 001, current set 002, the File replcia problem cannot be solved, Windows was unable to complete the Disk Check.
Plse Help Me..
This Is Ramesh - +91-09790923987 India.
Plse Help me..
then we can face the problme of
Make sure and keep copies of all the folders and files.
Take these actions to resolve your problem:
On all Active Directory registered domain controllers:
1. Stop NETLOGON Service
2. Stop File Replication Service (NTFRS)
On the PDC Emulator:
1. Rename all files in the %systemroot%\ntfrs folder and subfolders (change their extension to .old).
2. Give an unlisted account full control of the directory %systemroot%\SYSVOL folder and reset permissions on all child objects.
3. Change the registry key:
HKLM\System\CurrentControlSet\Services\ntfrs\paramaters\Backup/Restore\Process at Startup\BurFlags (REG_DWORD) = D4 (The default on this is 0)
4. Start the NETLOGON Service
5. Start the NTFRS Service
On all non-PDC emulators:
1. Change the registry key:
HKLM\System\CurrentControlSet\Services\ntfrs\paramaters\Backup/Restore\Process at Startup\BurFlags (REG_DWORD) = D2
2. Start the NETLOGON Service
3. Start the File Replication Service (NTFRS)
At this point, the system in question should have recreated the SYSVOL share and the NETLOGON share. Check this by running 'net share' from a command prompt. You should also see the Group Policy Objects listed in the SYSVOL directory as:
%systemroot%\SYSVOL\domain_name\Policies\{31B2F340-016D-11D2-945F-00C04FB984F9}
%systemroot%\SYSVOL\domain_name\Policies\{6AC1786C-016F-11D2-945F-00C04FB984F9}
There may be more directories listed here, but these are the Default Domain Policy and the Default Domain Controllers Policy that are installed by default when the Active Directory is created. If these are being replicated, then file replication is functioning.
If you cannot find these directories, then you may have to manually recreate them. Here is a list of the proper directory structure of the %systemroot%\SYSVOL folder:
\SYSVOL
________\domain
________________\DO_NOT_REMOVE_NtFrs_PreInstall_Directory
________________\Policies
________________\Scripts
________\scripts
________\staging
________\staging areas
________________\domain_name
________\sysvol (shared as SYSVOL)
________________________\DO_NOT_REMOVE_NtFrs_PreInstall_Directory
________________________\Policies
________________________\Scripts (shared as NETLOGON)
If you have to manually recreate the directories, restart the File Replication Service (NTFRS) on all domain controllers to re-enable replication. This should get the file replication functioning normally
There are a number of resources that you could check. My suggestions upfront are: MS TechNet, MS Forums, and EventID.
