Question about ASUS P5ND2-SLI Deluxe Motherboard
My vga port on my Asus mother board got damaged installed a vga card of 8mb but i'm not getting good graphic support. What should i do? please help....
  • ASUS Master
  • 11,800 Answers
You can't expect more from an 8MB video card. Get a better one.
Posted on Aug 02, 2010
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
I want to use a better vga but it isnt any port
Without a VGA port, you can't use a VGA card, pretty simple stuff.
If you want to add a video card, you will need to get a PCI video card (NOT PCI-E!) There are a number of them out there, and pretty much anything made in the last 3 to 4 years will be better than the on-board video...
Dec 18, 2009 | ASUS P5P800-MX Motherboard
Adding a video card and get no output
Look in the motherboards manual for info about installing graphics cards, see if it needs jumpers. Plus make sure you plugged the monitors vga or dvi on the right place (VGA or DVI port ON the graphics card, NOT on the old vga port you used to plug your monitor before )
See if it works otherwise tell me..
Sep 14, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Graphic related problem
Go to the asus website and select *********** board model .......
then select operating sytem ,then select graphics driver or vga driver download it and install.
your problem resolve.
Apr 06, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Graphic card will not display a picture or be reconized by the MB
1. whats the brand of the VGA Card ( looking at the model looks to like Asus)
2. when you tested the VGA card at the computer shop did they check it on a another motherboard?
3. any way fixing a VGA card is not possible by any ordinary computer repair shop. best would be to try to locate the local agent in your country & see the possibility of getting warranty.
Jan 08, 2009 | Computers & Internet
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
Maximum graphics card for 5yr old Asus AS99127F motherboard
yeah you can replace it witha VGA video card as long as it not over 8X speeds . Just make you you get a VGA card not a PCI-16 card
Jul 30, 2008 | Intel Motherboard
Asus mother board not supporting geforcefx graphic card
hi
read the motherboard manual carefully, whether ur mb have builtin vga. if its enabled, first disabled it u put the vga card and try to install the drivers as per the instructions carefully adn also u can get the drivers for graphic card GEFORCEFX 5200 from www.driverguide.com
Feb 22, 2008 | Computers & Internet
ASUS P5ND2-SLI Deluxe Motherboard Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
