Question about Samsung SpinPoint M80 HM080HC 80 GB ATA-100 Hard Drive
My SAMSUNG HM080HC USB Device cannot be detected, when I search it in "my computer". But it appears in "safely remove hardware". What's wrong?? tq
  • 214 Answers
Reinstall its driver
Posted on Aug 02, 2010
16gb pendrive
Which operating system ?
It's always a good practice to safely remove your USB flash drive before unplugging it from your computer.
This prevents data loss and extends the life of your external storage device.
Removing a flash drive from your computer is very easy and doesn't take a long time to do.
Close all files you accessed from the flash drive.
This is necessary for the device to be removed properly.
Don't forget to save your files before closing the files.
Right-click the "USB" icon marked with a checkmark.
It is located on the bottom right of your taskbar.
From the pop-up menu, click "Safely Remove Hardware."
A small window will be displayed.
Select the USB flash drive you want to unplug then click the "Stop" button.
A confirmation window will appear. Click the appropriate hardware device, then click "OK."
The "Safe to Remove Hardware" window will inform you that it's now safe to unplug the USB flash drive from your computer.
Click "OK," then click "Close."
or
Click start all programs accessories windows explorer navigate to your usb drive right click on it select remove or exit.
Jul 27, 2013 | SanDisk Computers & Internet
On Excel 7, before remoing the usb (removable stick. what are the steps
It's always a good practice to safely remove your USB flash drive before unplugging it from your computer. This prevents data loss and extends the life of your external storage device. Removing a flash drive from your computer is very easy and doesn't take a long time to do.
Close all files you accessed from the flash drive. This is necessary for the device to be removed properly. Don't forget to save your files before closing the files. Right-click the "USB" icon marked with a checkmark. It is located on the bottom right of your taskbar. From the pop-up menu, click "Safely Remove Hardware." A small window will be displayed. Select the USB flash drive you want to unplug then click the "Stop" button. A confirmation window will appear. Click the appropriate hardware device, then click "OK." The "Safe to Remove Hardware" window will inform you that it's now safe to unplug the USB flash drive from your computer. Click "OK," then click "Close."
Feb 08, 2013 | Dell GX270 P4 256/40/48X/XPP/NONE...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
My 8G usb can't be detected by my computer, my flash drive was brought 3 months ago and only half of it was used
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 11, 2011 | Office Equipment & Supplies
How to download or detect my webcam
1. Connect your web cam
  • Attach all power cords (e.g. laptop and/or web cam).
  • Plug your USB cam directly into your computer (do not use any external USB hubs). Turn your cam on
  • As long as your web cam and computer hardware are working, Windows should detect it!
2. Open Device Manager
  • For Vista
    => Click Control Panel. If you have Control Panel Classic View, click Device Manager
    => Click Control Panel. If you have Control Panel Home View, click System and Maintenance->Device Manager
  • For XP
    => Click Control Panel->System, then Hardware tab, then Device Manager button
3. Find your web cam in Device Manager
  • Understanding Device Names
    => Windows provides user-friendly device names to accomodate us humans. As far as Windows is concerned, the device name is simply a comment!
    => It's those cryptic Device Identification strings that really identify a device
    => Device Manager displays whatever device name it happens to find in the device driver
    ...==> If Windows finds NO device driver, your web cam may be named "Unknown" or "Other" device
    ...==> If Windows finds the WRONG device driver you may see your web cam with the WRONG device name
  • How to find your web cam
    => While your web cam is connected, look through all of Device Manager for devices with a yellow icon (probably a yellow question mark)
    => Be certain to expand the USB category to check all devices listed under it. Also, be sure to also check if category Other Devices appears in Device Manager and look under it as well
    => Your web cam will appear as a device with a yellow icon (probably a question mark)
    => Click on thumbnail to see the full sized image
  • How to verify the device you found is your web cam
    => Your web cam device will only appear in Device Manager when the web cam is powered on and connected
    => Disconnect your web cam. Verify the device you had found is no longer displayed in Device Manager
4. Find your web cam's Hardware Ids
  • In Device Manager, select your web cam device, rt click Properties. Click Details tab
  • Select Hardware Ids from the pull-down. You'll see a list of one or more Hardware Id strings
5. Search for a driver based on Hardware Id
> Update 1/26/2011: To avoid a common mistake, don't confuse the number zero with the letter "O". IDs may contain zero but NOT the letter "O"
The best driver will match the Hardware Id at the top of the list. The next best driver match will match the next Hardware Id on the list, etc
  • Start by searching for the Id at the top of the Hardware Id list
  • If only due to how different search engines work, recommend you cut USB\ from the search string
    => Example: If the Hardware Id is USB\VID_093A&PID_2468&REV_0001 search for VID_093A&PID_2468&REV_0001
  • You can start by clicking Search at the top of your TechSpot window to search TechSpot first
  • For more help on how to search for a driver using the webcam's Hardware IDs see this post
Feb 26, 2011 | ASUS Eee PC 900 Notebook
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Cant connect to pc
Dec 07, 2008 | Samsung YP-U3 MP3 Player
Unable to safely remove my portable device
If this is a USB device, you may remove it at any time.
Dec 18, 2007 | Samsung YP-U3JQB MP3 Player
Samsung SpinPoint M80 HM080HC 80 GB ATA-100 Hard Drive Logo
205 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
