Question about Creda Europa E010E Electric Single Oven
I have a Credaplan 48105 brown oven which needs replacement of do
I have a Credaplan 48105 brown oven which needs the main oven door replacement. Is there a contact in New Zealand??
Hi I need a list of error codes for an Angelo Po Combi oven. Model number is FCV101EDS
F0 - No Alarm Signal
The main control board in your oven has failed to communicate with the alarm. This is most likely a fault with the control board itself, which may need replacing.
F1 - Door Not Locking
If there is an issue with the door lock in your appliance you may see this error code. Check the door lock and the wiring and connections to it to get to the cause of the fault
F2 - Door Not Unlocking
The opposite fault to the above, this fault indicates your oven door won't unlock. Once again you'll need to check the door lock mechanism and its wiring and connections. This fault could also be down to the oven thermostat as this could be giving an incorrect temperature reading, preventing the door lock from being released.
F3 - Self Test Error
Turn off your appliance, unplug it for five minutes or so and plug it back in again. Doing so should clear the F3 error code. Easy as that!. If it does not clear the problem you are likely to have a fault so see the links to our diagnosis videos below.
F4 - Temperature Sensor Fault
If you see this error code you'll need to check your temperature sensor and the wiring and connections between the sensor and the main control board. You may need to replace the sensor.
F5 - Control Board Error
This fault suggests a problem has developed with the main electronic control board in your AEG oven. It may need replacing to bring your machine back to full working order again.
F7 - Mains Supply Issue
You'll see this fault if your oven has detected a problem with the power coming into it. This could mean your appliance has been wired in incorrectly. You'll need to check the mains supply connection to your oven to get to the bottom of this error code.
F8 - Power Supply Issue to Control Board
The main control board is not receiving power as it should. Check the wiring and connections to it. If all the connections are fine, you'll possibly need to replace the control board.
F9 - Processor Auto Resetting
As with error F3, turning off and unplugging your appliance for five minutes before plugging it back should reset and fix this fault code.
Oct 24, 2016 | Combi Ovens
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
Have a neff t1213xo, what does black grey and brown wires stand for?
You have an hob with European three phase at 220volt mains wire connected.
You need to to disconnect from mains connection box on hob and fit conventional British brown, blue and green/yellow.
Inside the connection box you will see three live terminals,(L1,L2 & L3) there are usually some brass links to join them all up and then attach brown core to one of them. If the links are not there then you will need to fit 2.5mm links from a piece of wire.
Nov 24, 2014 | Neff Ovens
I got brown marks on the top of the oven door when using the self cleaning mode. It is a white oven and now it looks bad due to the brown marks. Is there a way to get rid of these marks ?
The brown marks are caused by some food residue burning off during the clean cycle and is usually very hard to clean off. You might try using a Mr. Clean Magic eraser with some soft scrub. If that dose not do it you may have to replace stained parts.
Aug 28, 2011 | Ovens
Need a manual for CredaPlan Cabaret oven
This is not exactly your model, but should be close: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Creda/Cooking/HB48283.pdf
Sep 09, 2010 | Ovens
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
Aft self-cleaning, top of oven door and knob panel discolored
This is a problem with a bad door gasket, or a mis-adjusted latch. That needs to be addressed, then you can replace the discolored parts. The discoloration is permanent.
Oct 24, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Main oven door will not close properly. Is there any adjustment for it.
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
May 06, 2008 | Neff U1421 Double circotherm Electric Oven
Creda Europa E010E Electric Single Oven Logo
139 people viewed this question
Top Creda Ovens Experts
Craig Butler
Craig Butler
Pcm2048
Andrew Taylor
Andrew Taylor
Are you a Creda Oven Expert? Answer questions, earn points and help others
