Question about PNY Technologies GeForce 6200 128MB AGP Graphic Card
Whenever I put my PY Optima 8 GB card into my camera it says...this card cannot be used. any suggestions?
    President:
  • 2,571 Answers
Is it compatable, some devices dont like high speed SD cards, if it says SDHC or SDXC that may be your problem,
What is the maximum supported size you can use?
It may only be 2 or 4 GB
Has the write protect tab be knocked into the protect position?
If this is no help, please write back and i will look futher for you
Posted on Aug 02, 2010
Hi.....i am havimng a problem with my memory card PNY Optima SDHC 8 gb class 4......i have been using it in my sony camera....its was working fine at the start but recently after when i inserted the...
You will most likely find that your camera will work with cards up to a certain capacity e.g. 2gb
and not with cards of higher capacity. What this means in effect is that high capacity cards are not compatible with your camera. It would be interesting to know the make and model of your camera.
May 20, 2011 | Cameras
I have a Toshiba $GB SDHC Memory Card. I put it in the camera and camera says card is locked. I have slid the yellow lock button and it does not unlock. I also have PNY OPTIMA that has the same problem....
Your main problem is that you are trying to use a 4GB SDHC card in an approximately 8 year old camera which was only designed to accept a maximum 512MB SD card and which only worked reliably with 256MB SD cards. When your camera was designed, 128MB cards were the largest size available and so hardware testing only went up that far.
SDHC cards use a different memory structure to SD cards and older devices cannot use them even though they will fit in the slot. As it's a hardware limitation there is no firmware update option.
Your only fix is to obtain the correct type and capacity of SD card or to replace your camera with one which accepts SDHC cards.
I hope you manage to use this information to fix your problem or at least that it assists you to choose your next course of action. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Oct 02, 2010 | Toshiba PDR-3330 Digital Camera
Minolta dimage E323, 3.2 mega pixels i use a pny optima sdhc 8 gb and it tell ing me to reformat
This camera is NOT suitable for SDHC type cards, only SD cards with memory size till 2GB.
Sep 03, 2010 | Konica Minolta DiMAGE S414 Digital Camera
Have brand new PNY OPTIMA SD HC 8gb Have a HP camera Photosmart R927 Camera reads card is locked. How do I unlock the card?
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jul 06, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
I HAVE A DXG DIGITAL CAMERA. WHEN I HOOK UP THE CAMERA INTO THE VIDEO INPUT THE PICTURE IS ALL JUMPY & UNCLEAR
Here's my problem: I recently bought as in today a PNY Optima 16 GB SDHC Card for my DXG-566V camcorder. When I inserted the card into it's SD card slot (which I assure you I did correctly), and powered up the camcorder, the camcorder didn't recognize the SD card, as it was still running off of the camcorder memory! Now I know the camcorder is just fine becuase after that I inserted my PNY 8 GB SDHC Card and the camcorder recgonized the card.
Please help me out here!
Jan 12, 2010 | DXG Technology DXG-566V Camcorder
My z612 does not recognize any of my 4 sd cards. I can only take 8 pictures.Any suggestions?
E-mail your problem to Kodak at this address: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
Jan 05, 2010 | Kodak EasyShare Z612 Digital Camera
When I put in my SD 8 GB memory card, busy signal
An 8GB SD card will actually be a SDHC card, the HC means High Capacity. Your camera is only designed for regular SD cards up to a maximum capacity of 2GB; it's incompatible with SDHC at the basic hardware level and so cannot format the card.
You only have one solution: fit an SD card which does not exceed 2GB. Note that the specification for regular SD cards goes up to 4GB, but very few standard SD devices were ever designed or tested for compatibility with them. The few regular SD cameras which can use them mostly can only do so after a firmware update and even then will operate very slowly compared to when using a 2GB card. There has never been a firmware update to enable your camera to use 4GB SD cards.
I hope that you have found my posting to be of assistance and ask in return only that you return the favour by rating my answer.
Nov 01, 2009 | Jazz JDC87 Digital Camera
I have a kodak M1033 camara with a SD HC PNY optima 240 HD 16 GB and the camara says internal memory is full and is only 1/2 minute video in the camara please help
Hi!
Sonds like the camera hasn't switched to the memory card. Go to setup and set memory to Auto not Internal. If that doesn't help, it's possible that the camera doesn't support 16GB card, but it should give you a card error then, so check the memory settings first.
Tom
Oct 06, 2009 | Kodak EasyShare M1033 Digital Camera
SD Compatibility
nope. The largest it'll take is 2GB SDIO-compliant SD flash media. SDHC is right out of the window with this model.
Jun 07, 2009 | JVC Everio GZ-MG21 Camcorder
Computers & Internet Logo
35 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
