Question about MSI P4M900M-L Motherboard
Still no display
I've tried inserting video card external but there is no display and also i tried removing the memory card & reseting the jumper no display either but my cpu is still running...is it the motherboard defective? plz help me...thnx...
  • 101 Answers
Time to rectify and reprogram the BIOS on your mobo
Posted on May 03, 2008
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
My proline notebook is not displaying even when plugged in to an external Monitor.
When you plug in an external monitor, try to hit the combination Ctrt + F10 (or F7..depends on what key is designed for it. The key usually has a box picture on it) to make sure that you toggle displays between the laptop and the external monitor.
But if you've already done this but still didnt get any display, you can now go ahead and reinsert the memory module/s (RAM) of your laptop. A faulty or dirty memory module usually causes the unit not to POST (Power on self test). If you have 2 memory modules, try to gently clean the contacts using a pencil eraser and insert them one by one.
However, if this step will not resolve the issue, you need to consult help from an experienced technician. The video card of your computer is surely dead in this case.
Hope this helps.
May 27, 2011 | Computers & Internet
Hp g60t went into hibernation last friday it wouldn't come out of hibernation so i had to hold in the power button and shut down. laptop turns on but no video now the screen stays black. i tried a reset...
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Further, if the issue persists after performing the above steps, then the issue could be due to hardware malfunction of the video card or defective LCD display screen of the notebook. Hence, I recommend you to connect an external monitor to the notebook and then check whether the display works fine on external monitor or not.
Step 3: External Monitor
You can follow the steps listed below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
I believe the information provided would be helpful to isolate the issue with your notebook.
Jun 07, 2010 | HP G60t Notebook
Pc boots but no display. tried a new video card, still wont work. ram or motherboard?
Hi.
To start the troubleshooting,
Do one thing.
Clear the cmos.
To clear the cmos, remove the battery and the cmos jumper. You will see JCC on the mb and it is attached to pin 1&2
You can Short it to pin 2&3 or remove it completely.
Don't forget to remove the power-cord from the power supply while clearing the cmos. together with the cmos bat & jumper.
After that try a different ram and a different vga card.
At times dust get accumulated in the slot that prevent firm contact with the vga slot or the memory bank.
Use a clean paint-brush and blow away the dust on the card, the mem and also the slot in the mb.
Fix it firmly.
try this
If you need further assitance revert back
Good luck
Uttam
Feb 18, 2010 | Computers & Internet
Won't post, no beep. No display on monitor. Tried different AGP video card, different memory. I have unplugged everything but the AGP card and hard drive. The monitor works on a different computer so...
Basically, display card, RAM and processor are the ones affecting the display. IF trying different memory and video card doesnot help. Try changing the different processor. Thanx with regards Sajan
Jan 21, 2010 | Abit IC7-MAX3 Motherboard
Came back....turin it on....anything on the monitor
sounds like the hard drive is not spinning inside.
Sep 21, 2009 | Dell Dimension E520 PC Desktop
P4m800-m7 problem
Hi there
Remove the video card from the machine and connect the monitor to the on-board video, then reset the CMOS 3d40258.jpg, you will see a plastic jumper like the one in the picture near the battery, move it to the other position and power up the PC (nothing should happen which is good) then put the jumper back in the original position and power the PC up again. Hopefully the problem will be sorted and the problem was the video card.
Good luck and thanks for using Fixya!!
Feb 13, 2009 | EliteGroup P4M800-M7 Motherboard
Monitor no Desplay
reset the bios jumper settings,jumper it to 2 and 3 terminal, or do the erasing of memory card.
Sep 10, 2007 | Compaq CV 7500 17" CRT Monitor
Descktop computer turns on, but no video
Hi, I'm assuming your motherboard has a built-in video card. Let's trying doing it by the numbers. 1. Remove all memories, cards, FDD, IDE or SATA cables from the motherboard. What should be left are only the power supply connector, the CPU + Heatsink & fan; 2. With the unit off & unplugged, pry/remove the 3V memory battery. Short the CMOS reset jumper. This is normally located very near the battery. If you can post brand/model of MB, we can probably point the exact location or you can go to the manufacturer's website and download the pdf file of the manual; 3. Leave it with no battery and the CMOS reset (not default) jumper in place. Give it a couple of minutes; 4. Re-insert the battery and remove the jumper from reset position and replace it back to default position (its original position); 5. Connect keyboard, power cord, monitor video cable (onboard video connector is below the printer port and beside the serial COM1 port) and; 6. Power up. Most cases you will have a series or combinations of beeps since there is no memory (and no video since the onboard video uses shared memory). Sometimes no beeps at all. Power off; 7. Install a single stick of memory. It would be a good idea to clean the edges/connector pins of the memory stick with the use of a pencil eraser. Further use a clean/new paintbruh to remove any other dirt. Use the same brush on the slot where the memory is to be placed. Seat the memory into one of the memory slots. Power up, there should now be a healthy pre-post beep (if you do not have an onboard video, a long beep will tell you that no video card present). If no beeps nor display in your monitor, power off, remove the memory and place it in the other memory slot and try again. If still a no go, try with another memory following the same sequence. 8. If still a no go, try with your videocard either in AGP or PCI-E slot as applicable; 9. If it works, you're set to re-install everything else; 10. If not, your motherboard and/or processor has to be replaced. Hope this works out for you. Good luck and pls post again how things turn up. Kind regards.
Aug 05, 2007 | GE AGQ08AH Air Conditioner
MSI P4M900M-L Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
