Question about Acer PD112 Multimedia Projector
Projector make vibrate and sond - Acer PD112 Multimedia Projector
  • 89 Answers
The ventilation fan mounting is loose or the fan is faulty
Posted on Aug 10, 2010
Why does my projector make a very loud buzzing sound.
the buzzing sound will be a frequency vibration from the mains power cycles
check for loose connections, transformer mounts, loose bulb or any thing else that can vibrate
Apr 27, 2015 | Epson Powerlite 1720 Lcd Projector 3000...
Infocus 3916 Projector goes in and out of focus. It is a little less than 2 years old. Any suggestions for a solution?
Many of these projectors have a manual focus, and an auto focus. Make sure the auto focus is turned off in the menu options.
Then make sure the manual focus is not moving on it's own from vibration of the cooling fan. You can check this by manually focusing the projector, then taking a marker and marking a line on the focus wheels. If the projector goes out of focus, check the line you made and see if it has moved, if so. Your projector is going out of focus from vibration of the cooling fan, or the surrounding environment.
If your projector is mounted to the ceiling you can add a couple of rubber washers between the projector and the mounting bracket to cut down on vibration.
If your projector is sitting on a desk / table / ground, you can use foam padding to keep it from vibrating.
another solutions would be to temporarily tape the adjusting knobs while the projector is in use.
If your projector has a protective cap that is put on the lens when not in use, this will also push the lens out of focus, and will need to be re-adjusted each use.
Nov 20, 2014 | InFocus Office Equipment & Supplies
Optoma movie time projector has a vibrating sound
Normally this sound noise is the small FAN inside. Dirty or faulty. You must open the proyector, or go to some shop repair.
God bless you
Jan 25, 2013 | Optoma EP706 Projector Remote Control
Dell 3200MP DLP Projector: displays OK, but with vibrations soon as power button is pressed ON. found cause; rotating see thru thin plastic disk has a quarter of the disk broken off, thereby causing...
You need a replacement color wheel (that is the name of the broken plastic disc, likely glass). I have been unable to source one. Recommend you buy a used projector with a bad lamp, usually less than $100 on eBay and just put your good lamp into it. Keep your old one for parts.
Jul 04, 2011 | Dell 3200MP Multimedia Projector
Prowerpoint blinks to black and dings
sonds like a software conflict try uninstalling and reinstalling software or update drivers
Mar 18, 2009 | Epson EMP-S5 Projector
Vibration on Nokia 6085
dear,
go to profile option and then select silent... it will work for u.
Or go to sonds option and then select vibrate only option..
regards,
dont forget to rate it
Mar 07, 2009 | Nokia 6085 Cellular Phone
Problem with Vibrating
It could be an internal fan that is dirty or Just going bad. Hopefully this helps you...Let me know if i can be of anymore assistance. Also you can ship projector to me and i can look at it here. I am located in Louisville, Kentucky. Let me know. Thanks Jay
Jan 29, 2008 | Eiki LC-XB28 XGA LCD Projector Multimedia...
Acer PD112 Multimedia Projector Logo
60 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Marvin
Marvin
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
