Question about Comfort-Aire Heating & Cooling
Outside unit runs all the time set it on 70 during DAY and it still gets up in high 70s t
    Problem Solver:
  • 6 Answers
Pleas note, proper sized units may only reach a 20-22 degree split from inside to outside temp differance. This done so that moisture is removed thuss making us feel cooler. Sound stupid but our bodies feel cooler at lower humidity than higher. When we sweat the water on our skin eveporates making us feel cooler. It might be better not to look at the thermostats set tempature and maybe just walk inside and out of the house so you can feel the differance. As always you should have a professonial check the system and keep your filters clean.
Posted on Aug 02, 2010
Brand New Heat Pump Compressor fan turns on then off after only seconds.
What is the model number of the outdoor unit?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 09, 2017 | Heating & Cooling
My Goodman home air conditioner is freezing up during very warm weather. What is the correct high and low pressures for the Freon 22 during the running. I know it varys on outside temperature, so a chart...
The ideal pressures will be 68psi on suction and 225 psi on the liquid line.
If the pressures are close you should look for a blockage from dust in the evaporator coil,loose fitting air handler panels or a defective fan motor.
Jul 31, 2011 | Goodman Heating & Cooling
ON excessively hot days, the outside heat pupmp trips the circuit breaker. Most times it is only once, I turn the breaker to "on" and it works fine. Some days it pops two or three times. When the outside...
Hello I would add a HARD START KIT to the run capasitor (if there is not one already).This makes the compressor come on easy.If the breaker trips during running time the pressures are too high,hose off the condenser coil (fins).The unit might be slightly overcharged but I would be careful before adjusting the freon at all.
Sep 02, 2010 | Carrier 38CKC036 Air Conditioner
I am working on a M # GPG13420901AB. This is a 3.5 ton package unit that replaced a 3 ton package unit on 1700sq/ft single level home. Old unit was working fine but was replaced when the home was...
It sounds like you are low on charge. I think you have a thermostatic expansion valve and you need to check the subcooling, you should have 12 to 15 degrees at 95. At 95 degrees your head should be about 280# for a 12 or 13 SEER unit or higher depending on the effeciency. At 78 to 80 degrees indoor depending on the humidity, that is normal. The valve will open to try to fully feed your indoor coil and it sounds like your head pressure is to low to force enough refrigerant thru the coil.
Aug 16, 2010 | Goodman Heating & Cooling
Rv ac throws the breaker when outside temp gets high, unit works fine at night when outside temp cools down
Clean evap and cond coils
Place hand on a/c if too hot during the day but cool at night
then freon is being restricted in the condensor
Cleaning coils may help days
Put a trickle of water on the condensor during the day for a test.
.If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
I have a Ruud Model RQNA-B 13 Seer heat pump and it has shut down during this cold snap. It does this everytime it turns extremely cold and in the summer when it is extremely hot. Help, the service men...
If the outdoor unit is not operating and the electric heat is working, more than likely the outdoor thermostat is keeping the unit off.
This is an adjustable setting, doing it at the outdoor
unit. Typically the unit is ste anywhere from 15-35
deg outdoor temp. If it is 20deg outside and unit is not operating you turn it down to 15 deg to get the unit to run.
In the summer time if the unit is placed where it is
extremly hot most of the day, then the unit is
probably either shutting down to the compresssor
internal overload,which resets on its own. Or it
is tripped out due to a High pressure switch
whick can be reset manually or automatically depending on the unit.
The High pressure switch is located on the liquid line
which is the smallest of the two refrigerant lines.
If its a manual reset,just push the button in.
If you can get the unit to run, check to make sure
the outdoor fan is operating.
Good-Luck
Jan 09, 2010 | Heating & Cooling
Indoor unit temperature between 60F & 70F after R22 charge..
The pressure changes with temperature, it is not a true gauge to ensure a proper charge.
You should have a 15 to 20 degree temp drop across the evap coil. (return air vs supply air)
Can you verify that the compressor is running?
Not the condenser, but the compressor located inside the condenser (outdoor unit)
it really sounds like it is still undercharged.
Check the temp drop, let me know what it is.
Also tell me what the outdoor ambient temp is.
( for example.... 98 degree outdoors with 85 degree indoor temp could result in pressures something like 325 on the high side and 75 or 80 on the low side.
With the exact same unit, but 80 degree outdoor temp combined with 70 degree indoor temp, your pressures could read 215 low side and 55 low side. Not to mention that more efficient units often have higher pressures on the low side because they have more coil space and remove heat more efficiently)
Aug 21, 2009 | Sanyo Split System Air Conditioner
My rooftop Trane A/C unit shows high humidity on the thermostat, will not cool the house during the day but cools fine at night. What could the problem be? Also, how can I lower the humidity in the house?
High humidity causes Icing of the cooling coils. Avoid constant running of the a/c. Meaning let the AC pull the house dow 2 - 3 degrees at a time.. The unit shutting off will allow the ice to melt. Make sure the drain is clear by going outside and chkg for drainage. Once the house is reasonably dehumidified the ac can be set and left on its own.
Jul 06, 2009 | DeLonghi Trane 5t Rooftop Air Conditioner...
Outside air temp around 100 unit wasnt cooling good noticed evap coils dirty cleaned them cooled alittle better checked low side showed 90 lbs had friend reclaim to get it to 70 lbs 30 minutes later it...
90 psi suction too high possible bad valves or non condensablies in the system (AIR) what is the head pressure and what type of freon r-22 410-A? your unit is never shutting off watch out for that electric bill. and did you take apart the condenser and clean it? Tom
Jun 25, 2009 | Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Marvin
Marvin
Cesar Quant
Cesar Quant
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
