Question about Microsoft Office Professional 2007 Full Version for PC
I need to remove the genuine microsoft sottware my system....
YOu may be a victim of software counterfeiting THis copy of Windows did not pass genuine Wndows validation ask for genuiine microsoft software....This same problem is for me to what can do
Most suites or programs of Microsoft Office 2007 allows user to evaluate the product. The trial version of 2007 Microsoft Office system can be installed by using a 25-character trial product key available from Microsoft while you download the free Office software, and you can use the Microsoft Office 2007 suite or program with full functionality for 60 days.
You may have the Office 2007 CD and are able to install Office 2007 without entering product key. However, Office 2007 will work in reduced functionality mode, where it’s effectively just a viewer for Office documents. Beside, if you forget the trial product key, or don’t wish to register a Windows Live ID to get the trial key, here’s the trick to activate Office 2007, or more correctly, bypass the activation of Office 2007 60 days trial, and making the “trial” word disappear from the Office title at the top and suppress activation and trial expiry prompt.
Note that to use Microsoft Office 2007 beyond 60 days trial period, you need to purchase a valid license for it, available from Amazoni need to remove the genuine microsoft sottware my - ir?t=techgadgetrev-20&l=ur2&o=1 or most computer retail store.
To use this hack to crack activation on Office 2007, you need to install Office 2007 without any serial number or product key. If you have installed Office 2007 with a product key or serial number, do the following to clean remove Office 2007 of product key:
  1. Close all Microsoft Office applications.
  2. Run Register Editor by clicking on Start -> Run, and then type “regedit” in the Open box and press Enter key.
  3. Navigate to the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration
    Note that inside the registry key, there should be another subkey that resembles the following:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{90120000-0030-0000-0000-0000000FF1CE
    or
    HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{91120000-0011-0000-0000-0000000FF1CE
  4. If there is more than one registry entries or subkeys that reference Microsoft 12.0 registration, open up each subkey, and then identify the product by the ProductName value data until you locate the subkey for the product which you want to remove the existing product license key. For example:
    Product Name=Microsoft Office Professional Plus 2007
    Product Name=Microsoft Office Enterprise 2007
  5. Once found the correct registry subkey, delete the following values: DigitalProductID
    ProductID
  6. Close Registry Editor.
Once Microsoft Office 2007 has been installed with no product key, proceed with the following steps:
  1. In Windows Explorer, brose to the following folder: C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
  2. Right click on Proof.XML file, select “Open With…” in the right click menu.
  3. In the “Open With” window, select Notepad to be used to open the XML file. In Vista, if you can’t see the Notepad option, simply double click the “Other Programs” to unhide it.
  4. Scroll down to the bottom of the Proof.XML to locate the following lines: </Feature> <Feature Id=”SetupXmlFiles” Cost=”1248′>
    <OptionRef Id=”AlwaysInstalled”/>
    </Feature>
  5. Change the AlwaysInsalled to neverInstalled so that the line looks like following: <OptionRef Id=”neverInstalled”/>
  6. Save the Proof.xml file. In Windows Vista, you may need to take ownership and grant full access permission to yourself before able to modify the file.
  7. You can now launch Microsoft Office 2007 application such as Word, Excel, Powerpoint, Outlook and etc without prompting for activation.
As usual, as it’s a hack, and before you purchase a valid product key for it, you won’t be able to AND can’t access any updates or Microsoft Office Online.
Note: The hack may work for 60 days only. To make this hack fully working, try to delete additional file below, probably has to be deleted every two months:
C:\Documents and Settings\All Users\Application Data\Microsoft\OFFICE\DATA\opa12.dat
Or,
C:\ProgramData\Microsoft\OFFICE\DATA (for Windows 7 and Vista)
Disclaimer: This article is for educational and informational purpose only.
Posted on Aug 02, 2010
  • Tharindu Rathnayake Aug 02, 2010
    try this if that not work
    To bypass or crack the Microsoft Office 2007 and Microsoft Office 2003 OGA genuine validation, download and
    just click the *.reg file, and reboot your computer.
    Download
    If you need sn:
    Download
    Alternative way (old way):
    1. Install and activate Microsoft Office 2007 or other version of
      Office. If you intend to use the key-gen, you must install Enterprise
      edition.
    2. Download the patched OGACheckControl.dll.
    3. If you never validate your copy of Office, go to Genuine Microsoft Software web page,
      and run the Office Validation Assistant by using Internet Explorer (not
      Firefox as it will use different version of ActiveX component). This is
      to install the components required for Office validation. If you fail
      the validation – Office not genuine – simply ignore the message.
    4. Copy the cracked ogacheckcontrol.dll to the following
      \Windows\System32\Windows XP and Windows Vista (64-bit):
      \Windows\SysWOW64\
    5. Attempt to download Office files that require validation again. All downloads should work now.
"You may be a victim
Welcome to FixYa!
If you're seeing notifications that the copy of Windows that is installed on your PC might not be genuine, or that you might be a victim of counterfeit software, it's likely that your copy of Windows was not properly activated or is otherwise not genuine. To fix this, click the notification and follow the steps to either repair Windows or-if you have inadvertently obtained counterfeit software-buy genuine Windows.
If you are using Windows XP, download and install the Windows Genuine Advantage Notification Application. It will scan your operating system and will remove the annoying message if it's a legitimate copy of windows.
Download here: http://support.microsoft.com/kb/905474
Keep me posted.
Thank you for using FixYa.
Jas247
Mar 14, 2011 | Microsoft Office Professional 2007 Full...
Victim of software counterfeiting how to rectify it
Incase you are a victim of counterfeit product of Microsoft then :-
  1. Purchase a valid Windows XP cd-key online from Microsoft.
  2. If you can produce high-quality counterfeit media, along with a proof of purchase, you can get a free replacement key from Microsoft.
  3. Contact your reseller for redress.
  4. Purchase Windows XP from a local OEM reseller.
  5. Purchase Windows XP at a retail location.
Notice the word "Purchase" appears in three of those five options. There's almost no way to finagle a free cd-key out of this.
Counterfeit software can come from a number of sources. It's important to use a reputable reseller when purchasing software or PCs that come with software.
And, now the good part :-
Microsoft also offers several options to help victims of counterfeit software obtain a legal copy of Windows, including a complimentary offer for victims who were deceived into buying highy quality counterfeit copies
To help customers who unknowingly purchased a counterfeit version of Windows XP, Microsoft has created two genuine Windows offers for those who qualify:
  • Complimentary offer: Microsoft will make a complimentary copy of Windows XP available to customers who have been sold counterfeit Windows. Customers will be required to submit a proof of purchase, the counterfeit CD, and a counterfeit report with details of their purchase. Only high-quality counterfeit Windows will qualify for the complimentary offer.
  • Electronic License Key Offer: Microsoft will offer an alternative for customers who find out via the WGA validation process that they are not running genuine Windows, but do not qualify for, or choose not to take advantage of, the complimentary offer. These customers will be able to license a Windows Genuine Advantage Kit for Windows XP directly from Microsoft for a special on-line purchase price. The Windows Genuine Advantage Kit for Windows XP will include a new 25-character Product Key and a Windows Product Key Update tool that will allow customers to convert their counterfeit copy to genuine Windows XP electronically.
For complete details, please click on the foll. link :-
http://www.microsoft.com/genuine/downloads/faq.aspx?displaylang=en&sGuid=e15f48d2-e8e5-4e42-8f2c-3e1de84427cd
where you will find out how to contact Microsoft for this issue
Sep 21, 2010 | Microsoft Windows XP Professional for PC
I can`t go in my mail,I want to remove you may be a victim of software counterfeiting
HI,
That message ("you may be a victim of software counterfeiting") is displayed when your Windows serial number is being used by someone else. If your copy of Windows is legitimate, try contacting Microsoft support.
Take care,
Alex
Oct 13, 2009 | Microsoft Windows XP Professional for PC
I am a victim of software counterfeiting
my copy of windows did not pass genuine windows validation I am getting information about you may be a victim of software counterfeiting and desktop background color appears black? help me out.
May 30, 2009 | Microsoft Get Genuine Kit for Windows XP...
Victim of software counterfiting
You need to contact Microsoft.
Mar 19, 2009 | Microsoft Get Genuine Kit for Windows XP...
You may be a victim of software counterfeiting. This copy of Wind
you have a bootleg copy of windows. you will need to reinstall windows or you will not be able to update.
Mar 11, 2009 | Microsoft Windows XP Home Edition
Software counterfeiting,did not pass genuine windows validation
message appearing on the screen that you may be a victim of software counterfeiting.this copy of windows did not pass geneuine windows validation. hiiii this is msg displayed on my screen
software counterfeiting,did not pass genuine windows validation problem,
Jan 25, 2009 | Microsoft Windows XP Professional With...
"You may be a victim of software counterfeiting. This copy of Windows did not pass genuine Windows validation"
dude,
your using pirated software. it will work no worries about that. you can not update it anymore. to update and be safe from internet threats you need to install genuine Windows XP.
Dec 29, 2008 | Microsoft Windows XP Professional With...
This copy of windows did not pass genuine Windows Validation
It might be a pirated windows version.Contact the vendor and check for the serial number of the disc provided to you.Please do rate If this could solve your problem.
Dec 03, 2008 | Microsoft Windows XP Professional
Microsoft Office Professional 2007 Full Version for PC Logo
536 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
