KLEENMAID TOP LOADER kleenmaid washing machine stopped agitating
Kleenmaid washing machine stopped agitating
anyone do repairs in Canberra
kleenmaid extra large heavy duty commercial machine dont know number of the machine
now have 10 loads of washing to do and they add up at 3 per day
i HAVE PNEUMONIA AND CANNOT COPE
4 Suggested Answers
  • 410 Answers
SOURCE: How do I take off the agitator in my kleenmaid
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
  • 343 Answers
SOURCE: kleenmaid top loader replace timer
Kleenmaid timers do fail from time to time. Reconditioned timers are a viable remedy and not as expensive as new ones. Depending on where in oz you are, a tech will have to sight the faulty timer to ensure the correct replacement unit. You can't rely on model number alone........Nomess
Posted on Apr 18, 2010
Nitin_Master
  • 846 Answers
SOURCE: kleenmaid commercial heavy duty washer
Try this link
http://www.2instructions.com/results_mm.php?materiel=Washing%20Machine&marque=KLEENMAID
Posted on Dec 07, 2010
Kleenmaid
You should be able to download the instructions from this site.
http://www.kleenmaid-appliances.com.au/assets/pre2011_manuals/Use&Care/WM/kleenmaid/39237R4_LWK23_24_Op_Inst.pdf
In case you have a specific problem with the washer please describe in the comment section and the right expert on this site should be able to assess it.
Sep 19, 2014 | Washing Machines
Kleenmaid top loader replace timer
Apr 07, 2010 | Washing Machines
Kleenmaid top-load washing m/c leaks water and then smokes!
It sounds like you are leaking from the bottom of the unit. If you are leaking at the top then you need to check the water inlet valves, and also the drain pump and all water hoses. This doesnt sound like a seal issue.
Jan 02, 2010 | Washing Machines
Material chord lodged around agitator of kleenmaid KAW393 washer
sorry to saybut you would probley need to stripp down most of the unit...to remove chord.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do you remove agitator in Kleenmaid KAW793?
The agitator just pulls off- they can be very tight!! You need to get your fingers under each side of agitator and pull up. Kleenmaid do have a special tool to make this easier, but I have always managed to pull them out by hand with a good firm sharp pull upwards. To refit, just put it over the drive bell ( the plastic thing underneath agitator) and give it bit of a whack to clip it on. Good luck!!
Aug 24, 2009 | Washing Machines
Kleenmaid top loader Washing Machine Mod KAW 793W leaking
Problem turned out to be a leak from the top, not the bottom and was caused by debris blocking an overflow trap
Aug 03, 2008 | Washing Machines
Washing machine
This may be a little late, but it may assist someone else. On my Kleenmaid top loader I found the agitator has clips at the bottom of agitator that clip over a drive hub at the bottom of the "tub" . All you have to do is gently prise it up using your fingers between the bottom of the agitator and the bottom of the tub.
Paul
Jun 21, 2008 | Washing Machines
This may be a little late, but it may assist someone else. On my Kleenmaid (KAW693W) top loader I found the agitator has clips at the bottom of agitator that clip over a drive hub at the bottom of the "tub" . All you have to do is gently prise it up using your fingers between the bottom of the agitator and the bottom of the tub.
Paul
Apr 06, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
