Question about Panasonic CT-36HX42 36" TV
No volume T.V. works fine but no volume at all !!! Went through all the settings and can't find any of the settings out of place, unknown what to do
  • 49 Answers
Please connect dvd player through your tv audio/video socket and then watch the audio If it will okit is only audio out stage problem
Posted on Aug 02, 2010
There are a total of 4 users on my computer. I am the administator and for reasons unknown the sound has stop working on mine. I am running windows xp7. How can i restore my sound? Thanks!
seems odd 4 users all getting sound but you're not on same computer !
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 15, 2011 | Computers & Internet
Tried to play viedos on my gpx ml759b what happened is that it said unknown format
You need to use format factory and set it as all to mp4 then make sure the display settings are 320 x 240 and all should be good. I went all over the place trying to figure this out and this is what worked for me.
May 17, 2010 | GPX ML759 Digital Media Player
The vizio and the direct tv remote volume is not working correctly, installed new batteries to both. When you push to go up, it goes all the way up and down all the way down. It's like to have a mind of...
i had this problem using dish network. my dish remote went bad so i got a new one and as soon as i programmed it volume and channel had mind of its own on both the dish remote and the original tv remote. you would hit it once and volume would go to max and vice versa when going down. ended up being the new remote was set on the uhf setting and i had to reset to the ir setting which is a small switch in remote next to batteries and then reset system info in dish receiver. problem went away instantly. both remotes work fine now. took two days to figure out and spent hours on internet looking for solution but no one had one. hope this helps.
Feb 03, 2010 | Vizio VF550M 55 in. LCD HDTV
Wharfedale LCD3210HDAF blank screen
Wharfedale LCD3210HDAF this tv was working fine the night before .. when i turned it on in the morning the screen came on then instantly went blank .. although the sound is fine i am unable to get any on screen including menu an volume information and of course can any one help ??
Oct 27, 2009 | Televison & Video
No volume.
Are the tubes bad? Do they light up? Check the tubes and install replacements if necessary. If it's a preamp tube that went bad, just replace that one tube. If a power tube went bad then replace the set of power tubes. Be sure to get a matched set when replacing power tubes, and to bias them.
Aug 08, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Pendrive not working
1. Click Start. Click Run. Type cmd and press OK.
2. Type "set DEVMGR_SHOW_DETAILS=1" (without quotation marks) and press Enter.
3. Type "set DEVMGR_SHOW_NONPRESENT_DEVICES=1" (without quotation marks) and Press Enter.
4. Type "start devmgmt.msc" (without quotation marks) and click press Enter. It should open Device Manager.
5. Click View. Click Show hidden devices.
6. Click "+" to expand "Storage Volumes" and right click on everything that is under Storage volumes. Also, expand Disc Drive and uninstall everything present under this apart from your Hard Disc (Please make u dont uninstall Hard Disc)
7. If there any unknown devices right click it and click Uninstall.
8. Reboot the computer.
If this does not work please let me know.
Thanks
Nov 14, 2008 | Transcend (589307) Media
Verizon remote won't work
I am a Verizon tech and the remotes we use work for Vizio sets just fine. If for some reason the remote wont work and he tried 3 different ones then it has to be your set. I set FIOS up all day and have no trouble with those TVs
Mar 09, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Panasonic CT-36HX42 36" TV Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
