Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
My craftsman lawnmower 917.378941 runs about 10-15 minutes and then dies. I wait about 10 minutes, and will start fine and run approx 10-15 minutes again. It seems like it is getting hot and shutting down. Any advice would be greatly appreciated.
  • 252 Answers
Provided fuel flow is consistant and fuel tank beather is clear
sounds like the magnetron coil assy is going open circuit when hot
replace the magnetron with same type of unit as fitted to engine
two types could be used
1, standard magnetron ( has a piece of card between the halves of the iron lamination stacks
2 advancing style magnetron this unit looks like the standard one
except it has no card and has a wideish back gap at the ends of lamination stack
which ever one is used use same type
here is web site for parts
http://www.briggsandstratton.com/maint_repair/manual_and_more/
enter model and type numbers from blower housing on engine
good site check it out
cheers paul
Posted on Aug 02, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Voltage regulator
Sounds like a bad connection. The alternator only charges the battery, so if it or the voltage regulator in the alternator fails, the battery would slowly run down, not die all at once.
Jul 18, 2013 | 1994 Buick LeSabre
Briggs and stratton 6.5 Ohv dies after running for about 10-15 minutes. I let it sit awhile then runs again. This is a vertical shaft lawnmower engine.
This is a classic symptom of a blocked fuel cap vent. Next time it dies, remove the cap, wait 30 seconds or so (for carb to re-fill), then try to re-start. If it works, replace the cao.
Aug 07, 2010 | Briggs & Stratton Garden
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower runs fine for about 10 minutes>
sounds fuel starvation check the filter or the vent into tank is causing a vacumn
Aug 12, 2009 | Craftsman Garden
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
89' honda civic lx dies after 10 minutes or warms up?
it is probably your distributer. It has a internal amplifier and when it gets hot, it quits working.
Mar 25, 2009 | 1983 Honda Civic
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
888 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
