Question about Refrigerators
Freezer does not cold enough - Refrigerators
    President:
  • 1,099 Answers
The first thing I would check is condition of the condenser coil. If it's blocked with lint, the compressor will overheat and would not perform properly. In most cases cleaning could help to eliminate the problem. Remove the front and the rear panels and clean the condenser coil from any lint and dust. Wait about 24 hours to see if it works.
If this is not an issue then the cooling system could be low on Freon or the compressor has low capacity. To fix it you have to call a certified technician and it is going to be pretty expensive.
If your fridge is very old it is probably not efficient and it's not worth to fix it. It is possible your local utility company has a reimbursement program to utilize such old refrigerator.
Hope this helps
Posted on Aug 02, 2010
The freezer is not enough cold, i check the defrost sensor, temperature sensor and its are ok, but the evaporator fan motor is not working... why? i check this fan too and is ok. Now what can i do??
It could be on automatic defrost mode, let it run for a while and see if it gets cold enough, also if you have the freezer to full and stuff near the cooling fan in the freezer, the freezer can not circulate to get cold.
Mar 01, 2015 | Refrigerators
Why is the fridge and freezer not cold enough
If the fan isn't running neither section will be cold enough. There may be something jammed against the fan blade or the motor could be defective.
Jul 19, 2014 | Smeg FAB32RNN 50s Retro Style Black 304 l...
The refridgerator has not been cold enough, the freezer is fine what should i do?
The refrigerator itself get cold air from the freezer. There is a small opening that lets air from the freezer to go to the refrigerator area. make sure the cold air from the freezer is getting there. Sometimes there might be a restriction on this vent therefore the refrigerator is not getting enough cold air from the freezer.
Jun 28, 2009 | Amana AFD2535DES French Door Refrigerator
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Freezer just not getting cold enough. Freezer fan is running. Gasket, I thought was the original problem, has been re aligned. Light switch works and the light goes off when freezer is closed. Cold air is...
The defrost heater element is bad, Do you know enough engineering to tackle the job ? You will need some hand tools and a spare Saturday afternoon .. Alternaively you could call a technician...
May 05, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
