Question about Cell Phones
Cant change volume or ring tone have lost mannual
  • 55 Answers
Please first go to settings
& then click on to profile settings
& then click on to to customize
& then then select ring volume from their
& adjust the ring volume & save it.
thanks
Posted on Aug 02, 2010
Got a telstra easy touch dicovery 3. Cant turn silent mode off
Hi Shannon,
TELSTRA EASYTOUCH
DISCOVERY 3
SYMPTOM = No incoming ring or alarm tone
RESOLUTION:
- Check the ring tone and ring volume settings under
Profiles
- Check the handset is not muted (Long press the #
key
Apr 30, 2014 | Cell Phones
Ring tone volume low
possible the phone speaker is weak. cant do anything abt it.
Oct 15, 2013 | Google Computers & Internet
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Panasonic kx-tg2303 how do I change the ring tone?
With the phone off press the volume up and down button to ensure which ring tome you have. the up and down keys will change the volume. Now, press each of the keys 1 through 9 to select the ring tone you would like. Please let each ring tone finish before selecting a different one else the one you select next will not ring to let you know what it is.
cheers
Jun 08, 2010 | Panasonic KX-TG2303B/WH Digital Cordless...
How to change ring tone? Lost manual.
usually this is done one of two ways
if the phone has a menu button
press it once then use the arrow keys until you see "ring" or "ring tone" in the display
then use the arrow keys again and you should hear different ring tones. when you find the one you like press the menu button to lock it in
if the phone has a program button and no menu button
keep pressing the program button until you see "ring tone" in the display.then use the arrow keys until you hear the ring tone you like. then press the program button several times until you exit the programming mode.
you can follow the above steps to set the ringer volume also
Jul 16, 2009 | Uniden Cordless Phone
Low custom (individual) ring volume
This is not a B/B fault, unfortunatley the person who recorded the ringtone has recorded it at a low level, import into a wave/mp3 studio program and alter the recorded levels.
That is if you have tried the following:
Select Speaker Icon on the front screen of your 8100 (top right) press pearl in, scroll down to advanced, select the current profile (this is defaulted to Normal). Scroll to Phone and press pearl in.
Change Volume to High, if it's already on high, try the option above.
Gadget
May 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
Ring tone and volume of nokia n 70
The setting you are looking for is under "menu - tools - profiles - general - personalise" and you change ring volume and ring tone. When you understand this, you can also create additional profiles and switch between them for different situations.
Feb 10, 2009 | Nokia N70 Cellular Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
GE 25951EE2A phone
1. Changing The ring tones
You can choose ring tones (01 - 03) or melodies (04 - 13).
Press the Menu/Mute button until ringer tone 01 shows in the display. 01 is the default.
Use the cid/volume ( - or + ) button on the handset to select from 01 to 13.
Press Menu/Mute to save.
Nov 05, 2007 | Uniden Cordless Phone
Cell Phones Logo
149 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
