Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
When raining outside my tv screen gives wavy effect horizontally.when weather becomes dry, it gradually brings better result. any adice please to correct this problem. thanks and regards . pervaiz
What causes weathering
Entropy. All matter will go from an organized state to a disorganized state unless an outside force acts upon it. Cars will rust. Man can take rust out of the ground and produce steel with it. Weathering of rocks and landscapes are from wind, rain, acid (or chemical reactions) acid rain. The wind can erode using particles of sand to beat rocks and take layers off. gravity too allows erosion to wear sand and mud to gradually go into the sea or be carried off to other parts of the world.
Nov 26, 2013 | Cars & Trucks
Toshiba Model 51h84
The wavy when cold is a issue with a board in the set--Hyper board--the warmup until it begins to work will gradually get longer and longer.
The blue: look at set on a unused video input--if see faint curved blue lines with some blue visable on the screen the blue screen control needs to be adjusted just slightly down until the blue and curved lines are not seen.
May 15, 2012 | Toshiba 51H84 51" Rear Projection...
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
1994 Volvo 940, 4-cylinder non-turbo. Car starts fine when weather is dry. However, we have had recent cold/snow/rain and it is very damp. Car has full gas tank and good battery and will continue to crank...
I suggest that you look for secondary voltage leaks from the ignition system. Moisture causes dirt to become a pathway for this spark voltage. Look inside all wire connections, for any corrosion. A scope can test this, but typically a home does not have a scope...
Mar 16, 2011 | 1994 Volvo 940
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Green Screen
It can be a result of dry solder joints on the CRT base PCB, the PCB you see on the end of the CRT. Resolder all the joints on that board perfectly and thouroughly and this will be alright. Good luck.
Jan 14, 2008 | Samsung TXN3245FP 32" TV
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Jun 02, 2007 | Sony KV-35S26 35" TV
Wavy Screen on Startup
I gather from your post that wavy can mean two possible things as the TV comes on, you see the picture flow like ocean waves? In this case you may have 60Hz hum modulating with the picture, this is actually unlikely these days, but I have heard it happens sometimes. The other thing it could be is light horizontal tearing. This happens when the horizontal frequency is too high or too low. You are not going to like my solution because I feel that for problems like this the set must be analyzed not just subjected to "shotgun troubleshooting", so here I go, Take the TV to a repair shop.
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
