Question about Furuno Fcv 585 Color Fishfinder
I have a furuno fcv 585 and have an airmar 1kw ss264n-20 with a 10F pin plug on the cable provided that fits straight into the back of the unit, do i need the switching box mb-1100.
    New Friend:
  • 132 Answers
No, the ducer should have the diplexer built in to it.
the matching box is for bare wire ducers.
Posted on Aug 04, 2010
Furono585 constantly switches off after only 20-30 seconds
If you have a fuse panel with glass fuses, sometimes there can be corrosion between the fuse and the holder. Another check would be to go direct to the battery from the power cable and see if the same thing happens. Corroded fuse holders and bad crimps can cause this
Jan 07, 2014 | Lexerd - Furuno FCV 585 TrueVue Anti-glare...
I have a furuno FCV295 and when I was doing the initial installation set up of the transducer (airmar r299) I accidently chose the wrong settings. How do I re-do the transducer settings? The factory reset...
If you reset it and while in the Initial Settings" Menu, you press menu, it should take you to the transducer setup screen. These menus allow for "Transducer Type" to be changed to your exact transducer. See the "Installation Manual", which is different than the "Operators Manual". Section 3 page 9 and 10. You may have to enter your units of measure (Knots vs MPH, etc), and then it will allow you to choose the transducer type. Hope this helps. John Barry, 847-746-0100, technicalmarine.com.
Jun 19, 2011 | Furuno FCV 295 104" Fish Finder
INSTALLATION MANUAL FURUNO FCV-585 BEST GROUND FOR THE UNIT SHOULD I GROUND IT TO ENGINE OR BELLHOUSING OF OUTDRIVE
Attach to engine grounding point with battery cable. Add a grounding plate for RF (green) ground.
May 03, 2010 | Furuno Fcv 585 Color Fishfinder
GP700F Airmar P66 to TM260
you must run 50KHz for deep water, so you will have to solve the interference problem to benefit from the power
Oct 12, 2009 | Furuno GP7000F/NT GPS Receiver
Furuno Colour Video Sounder FCV-68 tech diag need.
most are available from furuno, but not FCV 68 are you sure that is the model #?
Apr 11, 2009 | Furuno 1623 Radar 16nm Range
LLOKING TO BUY A REPLACEMNET TRANSDUCER FOR A FURUNO FCV-582L
Yes, the current model of this is the FCV 585 and it is great. The transducer will need to be changed.
Apr 07, 2009 | Furuno FCV-582L GPS Receiver
I have a furuno fcv 585 echo sounder with a FURUNO CA50/200-12M -c13298 BRONZE THRU HULL HIGH PERFORMANCE TRANSDUCER. The transducer has 4 wires and it looks from the schematic that it attaches via a...
you need an MB1100 matching box has the 10 pin pigtail for your sounder and accepts bare wire input from your ducer
this will also ensure that all power from sonar get to ducer, but it from me if you like 847-746-0100
Jul 09, 2008 | Furuno FCV-582L GPS Receiver
Furuno 582L
those jacks are on a circuit board available from Furuno call me if you like 847-746-0100
Mar 23, 2008 | Furuno FCV-582L GPS Receiver
Installation furuno GP7000F/NT
This unit has built in sonar, so no DFF1 is required. The 1KW transom mount is in stock here, with the proper Furuno 10 pin connector. That is all you need, the display, the power cord, the GPS antenna, the transducer and THE BOOK! We are a Furuno dealer in the Great Lakes
Mar 03, 2008 | Furuno GP7000F/NT GPS Receiver
Furuno Fcv 585 Color Fishfinder Logo
373 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
David Burbee
David Burbee
Are you a Furuno Boating Expert? Answer questions, earn points and help others
