Question about Goodman CLJ48AR49 Air Conditioner
Compressor Cl J48-1
Please let me know where to buy the Compressor..according the repair guy, it does not work and the fan in the unit is overworking. He is charging me $180 just for the little compressor? What does this unit do?
thanks
troy
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
First, lets get the name right, capicator or compressor? if you paid it,then its right but a compressor is a lot higher,plus labor service call,parts liscenes,insurances ect..ect..ect...!
Posted on Jun 09, 2008
    Scholar:
  • 149 Answers
Have you tried replacing the capacitor ? get a 5-2-1 compressor saver and see if i'll turn on if it doesn't well compressor died...
Posted on Apr 26, 2008
How do u know if the cooling unit is bad
First, look behind the fridge at the bottom. There should be a thermostatically controlled fan that kicks on and off according to the cooling needs of the unit. That fan is what keeps the compressor from overheating and failing. After watching it for a while, if it is not ever turning, and if the compressor is hot to the touch, you need to replace the fan. I've done it - not that big a job. If the fan is working and the unit continues to not cool, you've probably got a bad compressor and it's time to call someone.
Jul 02, 2017 | Refrigerators
The compressor on my rls175 gets hot is this normal
wHEN A COMPRESSOR GETS HOT AND STAYS HOT NOT NORMAL, AND IS USUALLY THE RESULT OF OVERWORKING OR STRESSING THE COMPRESSOR? DUES TO EITHER LEAVING THE DOOR OPEN TO LONG TO MANY TIMES. A BAD DOOR SEAL, BAD THERMISTORS OR COLD CONTROL, OR A DIRTY CONDENSOR FAN AND COMPRESSOR OVER WORKING THE SYSTEM, ETC
Sep 23, 2014 | Hotpoint Refrigerators
Ge profile 26 pfss6pkx Light comes on but won't get cold, no fan running
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 15, 2014 | GE Profile PFSS6SMXSS 26 French Door...
Hello. I have a Bryant 561CJ030-D AC unit. The fan comes on but doesn't seem to be cooling. We have had record high temps the past couple of weeks (over 100 degrees), and I'm wondering if the...
Is the compressor turning on? The fan may be running, but you will not get cooling effect unless the compressor is circulating refrigerant. It appears your unit is a 2.5 ton unit. What is the square footage of the space being cooled? Is the space insulated?
Aug 04, 2011 | Heating & Cooling
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
Sometimes, when the inside blower shuts down, the outside compressor and fan motor continue to run for some time. Other times, when the inside fan motor is running, the outside fan and compressor motors...
The thermostat has a timer on the on- cycle (5 min delay for the outside unit and blower inside) if you are not gonna call a service guy then ( for $25) you can go to homedepot (whatever you got out there) and buy a honeywell vertical digital heat and ac t'stat.
this one doesnt require you to set it up for a particular application. this may solve your problem. but as for warm air out of the registers you need a service guy to check that
Mar 27, 2010 | Ruud UAKA060 Air Conditioner
Fan nor working on the outdoor unit.Hisense HFR 0922 split cycle air con. Double checked the wiring and is OK according to instructions in manual. Compressor working, but fan won't start. This is the...
If this is a residential, split system, try checking the capacitor. If the capacitor fails multiple times, check to see if the size of the wire for the unit is correct. Undersized wire can cause this symtoms. Very hard to diagnose.
Nov 21, 2009 | Heating & Cooling
When my ac cuts off there is a loud pop from the condensing unit
If the pop noise after turning off cooling or heating. In heating, this is the noise of the refrigeration system changing/adjusting itself and this is perfectly normal.
Mat
Jul 18, 2009 | Whirlpool ACE244XS Air Conditioner
Inside the air is blowing, but the outside unit fan isn't moving at all. HOUSE IT HOT!!!
Two things; outside does the compressor try to come on? If not you may have a switch\Thermotat problem. Also make sure the breaker to the outside unit hasn't tripped. If it has tripped there may still be a problem after you turn the breaker back on. If it's only the fan that's not coming on outside you will need a new capacitor or fan motor and compressor(if the fan motor is replaced you should have a new capacitor also. If it has been intensely hot your unit might have just gotten overworked. Then resetting the breaker is all that is needed. If you have continuos resettings you MUST call a qualified HVAC Tech.
Jul 12, 2009 | Goodman CLQ36AR49 Air Conditioner
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Goodman CLJ48AR49 Air Conditioner Logo
129 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
