Question about Union Pegasus F1228100PBV Series 5000 Shower Only Faucet, Polished Brass
New Pegasus shower valve that does not get hot water
I have a new Pegasus shower valve that does not get hot water. I have tried removing the valve and stem assembly and adjusting that, no result. I have checked the hot and cold shut-offs on each incoming line, both have hot and cold water at that point. When the shut-offs are opened, the cold water comes into the valve but the hot does not.
    Brigadier General:
  • 3,301 Answers
Single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Posted on Aug 02, 2010
2 Suggested Answers
meBNme
  • 334 Answers
SOURCE: I can't get hot water from the pegasus shower valve
The antiscald device needs to be adjusted. It's behind the escucheon and determines the amount of hot water flow.
Posted on Jan 13, 2009
How do I adjust water temperature on a Pegasus shower head?
Adjustment is usually on the valve assembly. Take off the big round trim ring and you will find the adjustment on the valve assembly or in the valve stem.
Oct 19, 2014 | Pegasus F1226700RBP 1100 Series Single...
Glacier bay faucet manual
Contact glacier bay to get a replacement control/handle assembly. Usually their customer service department is good at replacing the parts under warranty
You should have individual cold & hot water supply shut-offs in your basement for your tub/shower; if not, now's the time to install them.
If I could be of further assistance, please don't hesitate to ask.
Jul 28, 2014 | Pegasus 873-0127H2 Lyndhurst Single Handle...
No hot water comes out of shower just cold comes out even when turned to hot, sink 2 feet away has hot water
The problem more tha likely lies within the shower valve body. Possibly the shower head has an accumulation of deposits clogging up the holes but that would not affect the hot water supply only. You might try removing the shower head and turning on the hot water. If you get hot, immerse the head in Limeaway for a hour or two and replace it, or install a new head. If you still do not get hot water, the shower valve needs attention. The cartridge inside the valve body will likely need replacing or at the least cleaning (Limeaway), replacing rubber seals and use plenty of silicone grease before re-assembly.
Oct 26, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
I cannot get the water hot enough and maitain the water pressure. The groved thing in center (after removing all hardware and sace plate) is missing the red/blue clips. I am a complete novice and don't...
pegasus is a home depot product u need to adjust ur anti scald setting the valve is shipped in cold position it should have a red and blue plastic clips that go over the grooved thing call pegasus customer service at 1888 328-2383 they should be able to assist u with ur problem if u need parts or how to adjust the anti scald system
Jan 03, 2010 | Union Pegasus F1228100PBV Series 5000...
Have a pegasus shower single valve ..cannot determine how to adjust the hot water to increase it. Have hot water in bathroom sink.... renting this place...owner has no clue. removed handle and all that is...
when it is sold the anti-scold is set at cold to protect the buyer -the piece with the groves on it is the stem their should be two plastic clips a red and blue that slid over it these clips are the adjustment -also give pegasus a call they have an 800 number to assist u or home depot the carry the brand
Nov 09, 2009 | Union Pegasus F1228100PBV Series 5000...
How to remove the cartridge from my pegasus shower/bath faucet. the instructions are not very good.
remove handle , unthread collar , same with chrome body base . make sure water is turned off from valve
Oct 18, 2009 | Union Pegasus F1228100PBV Series 5000...
Single handle shower valve.. can't get any hot
factory set is usally cold for safety. remove handle, then remove cover. you will see the mechanism, bunch of plastic teeth, set it up in the middle, then try it, repeat process till you get desired temp
Aug 01, 2009 | Home
Why is it that when I turn on the water on my Pegasus K800 tub and shower faucet, water comes out of the spout and the shower head. It is brand new
Your diverter valve probably has a loose washer or seat. It could be defective, but try to tighten the washer and seat first.
Regards, --W/D--
Jul 20, 2009 | Pegasus Technologies Home
Water heater has hot water in it but cold water is still flowing
Nothing wrong with waterheater. Did you perhaps reverse hot/supply lines on new shut off valves?? try reversing lines. Maybe
Please rate. Thanks jj505
Mar 28, 2009 | Whirlpool Water Heaters
Jan 13, 2009 | Union Pegasus F1228100PBV Series 5000...
Union Pegasus F1228100PBV Series 5000 Shower Only Faucet, Polished Brass Logo
921 people viewed this question
Top Union Home Experts
john h
Tom Chichester
Are you an Union Home Expert? Answer questions, earn points and help others
