Question about Maytag Dryers
Loud clunking noise in gas dryer, though it was functioning OK otherwise. Afraid it would get worse and really break something, I opened and the belt looks fine. I took out the drum and found that the noise is in the motor, when it turns. What's the likely cause? Bearings? Can it be fixed or does the motor need to be replaced? Is it worth it? Is it OK to just let it run with noise until it dies? I also found that the assembly that holds the idler wheel is loose where it attaches behind the motor, but maybe it's supposed to be.
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerLoud clunking noise in gas - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Aug 03, 2010
Screeching noise
check your brakes if it feels as if something is dragging a caliper could have fallen or brake pad is stuck or your emergency brake is stuck I suggest looking into your brake system
Oct 08, 2013 | Mazda MX-5 Miata Cars & Trucks
2000 Cadillac DeVille sounds like prop-plane on acceleration
Could be the serpentine belt rubbing on something, but is probably a bearing problem in the belt idler pulley. However, it could be the power steering pump, AC compressor clutch or generator. As the water pump is at the opposite end of the engine, it's probably not that.
Apr 18, 2017 | 2000 Cadillac DeVille
Still turns after opening door
When the door is closed the switch will close, allowing power to circulate through the rest of the circuit. When the dryer door is open the switch will open, breaking electrical contact to the neutral connection of the circuit and stopping the flow of electricity. so it sounds like a bad dryer door switch.
Feb 02, 2012 | Frigidaire Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Maytag LDG9334AAE Gas dryer making popping noise from vent
clean clean clean everything, dont let it go to much longer or you will have a fire, and dont ignore this or you regret it... then tell me if it makes the noise
May 07, 2009 | Maytag Dryers
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Dec 14, 2008 | Kenmore Dryers
LG DRYER MAKING CLUNKING NOISE
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
Oct 16, 2008 | LG DLE5977 Electric Dryer
Loud dryer
  • it sounds like a bad roller. if you know how to take the drum out of the dryer then you can do this repair. no special tools are required.
  • you can get step by step (with pictures) instructions at this site.
  •  www.fixitnow.com
Jul 02, 2008 | Kenmore 72982 Gas Dryer
Dryers Logo
95 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
