Question about Home
I can't figure out how to make my scale display pounds instead of kilograms
  • 33 Answers
Depending on the make and model, there may be a switch on the underside of the scale, or inside the battery compartment.
Posted on Aug 02, 2010
Salter scales weighing more than double the weight
Sounds silly but check the scales for a Kilogram or Pounds switch. its usually under the scales and is a sliding switch. It should tell you on the display if you are weighing in pounds or kilos.
Sep 15, 2014 | Health & Beauty
Cannot get it to simply read weight in pounds
Hi dave,
Here is the Simple example of converting weight to pounds.
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Hope it helps.
Thank you for using fixya.
Sep 09, 2011 | Health & Beauty
Instead of showing my weight in pounds (168.00), the window is showing a different kind of number (75.). I don't know how that happened. What should I do to correct this.
Your scale is showing you your weight in kilograms what you need to do is change the settings so it shows you your weight in pounds or stones
Sep 19, 2010 | Conair Weight Scale "Thinner" with Body...
How do I change the scale to read pounds instead of kilograms?
Turn over the scale, on the bottom, there should be a little black switch that you can use to select between lbs and kilograms.
Oct 25, 2009 | Taylor 5599 440 Pound Tempered Glass Body...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Metric instead of pounds
You didn't mention brand name or model number, so not sure about your specific case. However, on my scale, there is a switch or button near the battery compartment. It allows you to change the measurement between stones, pounds and kilograms.
Jan 01, 2009 | Health & Beauty
I have a tanita tbf-612 scale and the measurement changed to metric instead of pounds when the batteries died. How can I change it back as I don't see anything on the back to re-set the scale.
Home Logo
55 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
