Question about Microsoft Xbox 360 Console
Plug in audio/video cables and get sound, but no picture.
    President:
  • 1,139 Answers
Try resetting the video back to standard definition by holding the power button down for 5 seconds.
Hope this helps
Posted on Aug 02, 2010
I HAVE SOUND BUT NO PICTURE PLEASE HELP!!!
Maybe you plug cables in wrong hole.
Make sure you have plug in all audio and video cables between your TV, adapter, and antena / signal receiver devices. Of course you must plug a those cables in the right position, they usually have color or mark identification, for audio and video.
If you feel this useful, RATE please !
Jan 20, 2011 | Televison & Video
How do i hook up the cables to get a picture and sound?
To hook up the cables to get the pictures and sound of your television, all you have to do is to look at the back of the cable, you will see the port that shows audio out, plug in a prong there and trace the prong and connect it to the televisions audio in, then you take the other prong and plug it in the video out of the cable then plug it on the video in of the television.
That should do the job.
Ensure that you have your cable properly connected to the satellite.
Take care and good luck
Oct 30, 2010 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
Jan 03, 2010 | JVC AV-48WP30 48" Rear Projection...
How do i get s-video to work
The S-video is an upgrade connection for the Yellow video plug. Use the S-video cable and the two red and white audio cables to plug in your item source to the TV. Leave the Yellow cable unplugged. The picture and sound should come in without changing any settings.
Jul 09, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Picture received no audio
Check if ur PC sound card works Fine. If it does Then Open Sound Settings In Syatem taskbat and set LINE IN as recording Plug.Increase The recording Volume of LINE IN.Make sure u plug ur Microphine cable of the webcam into LINE IN slot of ur sound card.Then Check...........
May 26, 2009 | Creative Labs Live! Cam Video IM Pro...
How do you hook up a dvd player to the panasonic 10801 hd tv
the easy way is RCA cables..Plug the video out of the dvd into the video input of the t/v...then plug the audio -right & left out of the dvd into the audio input of the t/v...For a great picture use an S-video cable from the dvd to the t/v BUT thats just for the picture not the sound. you still need rca cables for sound
Dec 19, 2008 | Televison & Video
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
DVD from laptop to computer
MaionP:
you need to connect your TV to your laptop with the audio cable as well. A simple S video cable will only gives you video. You can buy a simply audio video cable and use the audio output from your laptop to your TV and keep on using the S video for video.
Or you can use simple external laptop speakers to gives you sound with your TV output.
Hope that helped!
Dec 09, 2007 | Computers & Internet
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
