Question about Air Tools & Compressors
I need a repair manual for a Puma air compressor model PP6060v
SOURCE: Need a manual for a Coleman Powermate air compressor Model #VP0200608 Elec.
I'm looking for a owners manual for a colman powermate air compeser modle cl0502710
Posted on May 04, 2009
compman66
  • 169 Answers
SOURCE: ingrsoll rand air compressor repair manual
Most manuals are available from Ingersoll-Rand, I am not sure they sell a repair manual. however they do have owner and parts manual for the pumps that show breakdown of the pump and can be very handy for reference when working on one. Contact your nearest IR air center and ask for a copy of the manual, and most times they can provide you a copy for little or no cost.
Posted on Jan 15, 2010
SOURCE: Need manual for a Kawasaki model 840703 5gal 3hp
I called 1 800 590-3723 and they are e-mailing a manual to me. For my model (3HP twin tank) they said 10W30 or 5W30.
Posted on Feb 26, 2010
SOURCE: Need a copy of a manual for an air compressor
Go to Campbell web site,then call them
Posted on Jun 01, 2010
  • 1388 Answers
SOURCE: I need a maintenance manual for model HL700200 air compressor
The following address will provide you with all the info that you need to maintain your compressor. Good luck
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=HL7002
Posted on Jul 12, 2010
Where can I get a new pressure switch for my puma 6060 air compressor
Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
Feb 26, 2015 | Puma Air Air Compressors Puma Air PK6060V...
How do I fix my pressure switch on my puma 6060 compressor
Need some details, exactly what is it doing or not doing incorrectly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
I need to fix a leak in my pressure switch
You don't repair a pressure switch, you replace it.
Nov 28, 2014 | Puma Air Air Compressors Puma Air PK6060V...
What compressor oil do i need for my puma air compressor
Any name brand compressor oil will be fine, just make sure to drain the old first, and then refill
May 30, 2014 | Puma Air Air Compressors Puma Air PUK5520G...
How do I wire my puma 220v sigle phase air compressor with s-p40t motor starter?
You contactor /motor starter has connection for up to three phase /L1 thru L3. You will be only using L1 and L2 connectors for power-in/ line and using meter find cross connector for connecting load / motor (usually white and black or red from the motor). The contactor has a push button to test your work (use meter to test before actually wiring up motor and line). The contactor is controlled by separate switch (usually pressure switch on the compressor) using proper voltage as required by magnetic switch of s-p40t. Good luck
Apr 06, 2014 | Puma Air Air Compressors Puma Air PK7060V...
I need to convert mu Puma PPH 30-10 air compressor from 220 Volt to 110 Volt wiring, but I do not have the owners manual or a wiring diagram for it. The Motor is a GE
If this is a 3HP I don't think you can switch it. However there is usually a wiring diagram under the square box on the side of the motor.
Sep 29, 2013 | Puma 3-HP 60-Gallon Belt Drive...
Where can I get an owners manual for my Puma PN1004 air compressor?
This is a Taiwanese company and their web site leaves much to be desired - I was unable to get the manual for you but I did get an email address for you to possibly get it from;:sales@pumaair.com . I'm sorry I couldn't find more for you but here is the web address in case you need it; http://pumaair.com/english/products.php3 . I hope this helps!!
Dec 15, 2010 | Puma 1Gallon Mini Hot Dog Air Compressor ...
Need a service and parts manual for a puma pk-6060
Hi, my name is John. Welcome to FixYa. You can get it here. www.mastertoolrepair.com . Thanks for choosing FixYa...John
Nov 20, 2010 | Puma Air Tools & Compressors
Air Tools & Compressors Logo
691 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
