My sharp aquos lc52d65u dosent turn on. the power light blinks 5 times, stops for 1 sec, and start bliking 5 times. can you help me please.
  • Televison & ... Master
  • 17,130 Answers
It is possible that there is a failure of some components in the main board or a possible break of connectivity. You must be familiar to open the set and have some basic knowledge of the electronics inside. Use a good source of light to check for physical indications of burnt out, dry solder joints or connections.If after soldering there is no result then you will have to take a voltage check and see for any short in the main output drive, short in the capacitors. Take your time to make a good check for open circuits as the feedback is required for the smps to power on. Hope you get this right. Good day
Posted on Aug 02, 2010
What are the symtom of power supply failure on Sharp Aquos?
I made a video on what mine was doing and how I fixed it with a power supply. Mine was blinking 3 slow then 1 fast.
Aug 27, 2015 | Sharp Aquos Televison & Video
Sharp Aquos TV doesn't work, power light is blinking at 1 blink/sec
Sounds like a fault code, ~I have found some info on it:-
The frequency and color of the blinks will indicate the issue. There is a hold-down button sequence to try to backdoor your way into the set to see if the panel will light. You may have simply racked up too many "weird tuner faults" and need to reset it. My suspicion is that it's either that or bad panel backlight.
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state.
hope it helps
Aug 23, 2014 | Sharp Aquos Televison & Video
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Aquos lc40le821e. LED is blinking constantly at a rate of 1 blink / 2 secs. Cant get the tv on. Any ideas? Thanks.
Sharp LCD tv tend to have trouble with power LED light and OPC light flashes together?That what u having?Yes,this tv is having trouble with it tv Tuner signal board itself.This tv is still useable.By pushing the power button again and wait for awhile than the backlight will come on and work,Sometime Power and OPC LED lights flashes quit awhile.Just have to push power button and wait have to do this 3 or 4 times,before tv backlight to come to work.I have a Sharp Aquo my self 46' do this most of the times.
Jan 01, 2011 | Sharp Televison & Video
52inch Sharp Aquos has a constant blue blinking power on light no picture at all.Tried the resets,still the same,installed new inverter boards,still the same.Now what?
This problems is not those 2 long LCD inverter boards problems,why did u replaced those 2 long LCD inverter boards?I fix this problems before for a 46" LCD Sharp Aquos L46D55U tv.This problems,it the Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 08, 2010 | Sharp LC52D65U 52 in. LCD TV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
Sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Jun 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
