When i print all my photos, documents,etc. cyan line are visible in my print outs. how can i overcome this problem
  • 17,130 Answers
Please try to uninstall the software in your PC after disconnecting the printer and then reinstall . Reconnect the printer then and detect the device . It must solve the issue as this fault could be a software based issue. Hope the inks have been installed with the original and was not done recently , if so check the quality of the inks or the carrtridges. Hope you try. Good day
Posted on Aug 02, 2010
Problem printing yellow.
IIf the cartridges is original epson there is some color (light magenta that is clogged.
if the cartridges is non original check that is with the right order
Apr 23, 2015 | Epson Stylus Photo R300 InkJet Printer
Cl7000 cyan fades on one side of the print,prined black red etc and good, chand the photo and drum .
try cleaning the laser shield glass for cyan. you said you change photo and drum. Does that mean developer unit for cyan and cyan drum unit.
Sep 30, 2014 | Ricoh Aficio CL7000 Laser Printer
My printer epson is printing yellow background with any document i print. what can i do to stop this
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
Feb 16, 2010 | Epson Stylus Photo 820 InkJet Printer
Canon Pixma iP4600 not printing cyan
I had the same problem and I finally FIXED IT. I first tried replacing cartridges - no good, I then took the print head out, dismantled it and washed every component, no good. I then noticed that there were small streaks of blue on the paper when I tried to print a blue image so I worked out that the blue ink is getting through, but very slowly (yours might not be getting through at all but don?t worry this should still fix it). So I got a very thin pin and pushed it into the cyan pad on the print head creating a thin channel for the ink. Tried to print again, perfect, blue now working. Hope this helps - remember, you do this AT YOUR OWN RISK, there is no guarantee this will work for you, it worked for me but there is the obvious risks that you may break your printer. I did it because it was broken as far as I was concerned and I had nothing to lose if it broke completely, you must make that choice yoursel
Aug 25, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Cyan not printing,
PURCHASE A NEW CARTRADGE OF GO ONLINE
CANON 850i WILL NOT PRINT IN CYAN
SEE IF ANYONE ELSE HAS THAT PROBLEM AND HOW THEY SOVLED IT
ROD
Feb 02, 2009 | Canon i850 InkJet Photo Printer
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Photo printing
It is definite one cartridge is not running. You do one thing - 1. Write documents in MS-Word - select all - change the color to Red. Take print out. Check Printing is perfect or not.
2. Write documents in MS-Word - select all - change the color to Cyan. Take print out. Check Printing is perfect or not.
3. Write documents in MS-Word - select all - change the color to Yellow. Take print out. Check Printing is perfect or not.
I am sure when you changed the color to Cyan - it did not print Cyan or blank page you got.
So you must replace the Cyan cartridge or may be ink is not coming out through the passage. And first you have to check whether you have removed the plastic tape from the head of t he cartridge.
Oct 25, 2006 | Canon I900D InkJet Photo Printer
26 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
