Question about Maytag Neptune MDE5500AY Electric Dryer
No hot air
Dryer has not hot air. otherwise, all else seems to be working
  • thesmooters Aug 02, 2010
    Maytag Neptune Electric ryer
  • Maytag Master
  • 43,501 Answers
Hi, If you have a gas dryerno hot air - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dno hot air - 2_bing.gifrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 03, 2010
I have a kenmore 110.87561601 dryer, it blows warm air but not hot, is this the norm for it?
Check power at the outlet. If you're not getting the full 240v then it'll come out warm but not hot. Otherwise I would go with the timer.
Oct 01, 2014 | Kenmore Dryers
The dryer does not seem to push hot air into the drum. The heating element works in that I can feel it being hot, but there does not seem to be much, in any, hot air being pushed into the drum.
Make sure that the vent is not blocked. Also check that the fan is not broken (reasonably common). The fan is bottom right once you remove the front panel.
Dec 11, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
My Frigidaire gas dryer isn't hot. Otherwise it runs fine.
it could be either your ignitor(glow coil) flame sensor control, or a defective thermal switch telling dryer its at temp and shutting off gas supply before it even fires initially
Oct 17, 2009 | Dryers
I have an Acer Aspire 5515 laptop. When Im typing the lers sometimes dont show up. Ihav to hit the letter key a couple times for it to work sometimes. any suggestions on how i can fix it?
first of all u need to remove ur power plug and the battery
then pull a little Aciton around each button which stuck
use any cool air dryer and direct it through these buttons which u have put an Aciton on it
keep ur cool dryer ( not hot air cool air plz) about 5 min. directed to the buttons
leave it about 30 min
if this not work then try this
u need to clean ur keyboard cause it seems that ur key is stuck so u need to dissassemble ur keyboard and clean the carbon points in ur keyboard (after u dissassemble it) using Aciton and tishue
otherwise u need to change ur keyboard
Jul 30, 2009 | Acer Computers & Internet
Dryer not blowing hot air
you either have bad element or bad thermo disk or thermo fuse
Jul 01, 2009 | Kenmore 63942 Dryer
Dryer overheats and shuts off- vents have been cleaned and button on back has not reset
Common problem.
You probably need to clean
your dryer vent. Dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
I'm pretty sure that's it. Good luck.
Apr 15, 2009 | Asko T731 Electric Dryer
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
Bottom face of dryer excessively hot
That is where the fan is located, hot air is drawn from the hearer at the rear of the drum, through the drum then through the fluf filter at the front (inside the front edge) and then down the front panel and to the fan, then via a duct to the rear. So would get warm at this part.
Would check that the external ducting is clear and not kinked, flexible plastic or foil ducts should not be used for these machines ie fixed ducting only.
Mark
Jun 01, 2008 | Maytag PYE2300AY Electric Dryer
Maytag LDE412 Dryer
the vent that takes the air from the dryer out of the house is clogged. not the part right behind the dryer but from where it goes into the wall to where it leaves the house needs to be cleaned. when the air cant leave the dryer at normal speed it takes for ever to dry a load of clothes
Nov 26, 2007 | Maytag MDG7600AW Gas Dryer
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
134 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
