Question about AEG 6600 Bagged Canister Vacuum
Vacuum cleaner air max aam 6105 has problem of power adjust dial.. I disassembled cleaner, potentiometer(variable resistor) of circuit was out of order.. Can I purchase a potentiometer? I cannot get the same component in my country..
How do I adjust the brush level on my Navigator DLX vacuum cleaner
The illustration accompanying your post shows a typical level adjuster. It is the round "dial" on the housing.
Jan 26, 2015 | Vacuums
Why is my Dyson DC59 is empty but the max light is on and it won't work
it would mean that your air flow is gone or you have a plug in it some where about 90 % of all bag full or max light work on air flow
Jul 26, 2014 | Dyson DC44 Animal Cordless Vacuum Handheld...
Dw621 pulsing speed problem
Try to start it at various speeds. Use contact cleaner on the switch, and the variable speed control resistor.
Mar 02, 2014 | Dewalt DW621 2 HP Evs Plunge Router W/...
Sebo Vacuum runs intermittently and keeps cutting out and restarting
There could be numerous reasons for this. What I would try in this order to help troubleshoot is this:
1. If you wiggle the power cord near where it inserts into the vacuum cleaner itself, does the vacuum turn on and off constantly? If so, you have a damaged cord or loose connections that need to be fixed.
2. Has the bag been emptied, and if the vacuum has a filter element, has this been cleaned? Vacuums may cutout if they get too hot. A vacuum can overheat if either the bag is full, the filter is blocked, or there are other obstructions to airflow, which cause the motor to work harder and draw more voltage, resulting in more heat. It may have a thermal cutoff which is tripping constantly. Solution is to ensure bag is not full, or less than 3/4 full, any air filters are cleaned and check for any other obstructions in the air flow paths.
3. Ensure the power supply is adequate for the vacuum. Try running it without long extension cords if you have been using those.
4. Check and clean the switch. Sticky or dust contacts on switches can cause variable cycling (cutting out and restarting).
Hope that helps!
Mar 11, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Non working roller brush on dyson dc25 vacuum cleaner
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 08, 2010 | Dyson DC25 All Floors Bagless Upright...
The red light on my electrolux vacuum comes on and cuts power.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Jan 03, 2009 | Bosch BSA2222UC Compact Plus Bagged...
Height adjustment
You'll have to turn the upright to its side to show the sole plate where the rolling brush is. Check where the front wheels are located and ensure there is no blockage obstructing the rotary dial. Sometimes the spring mechanisms can work themselves loose.
Inevitably you'll have to remove the sole plate and/or the rotary dial which may be screwed down. If it has cracked then you may have to seek a replacement.
Dont forget to rate this suggestion.
May 25, 2008 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
Miele S2511 Vacuum Cleaner Disassemble Question
My problem is with the power brush...I checked the belt and cleaned the rotating bar..still very low suction. The canister is still giving me plenty of power...thanks for any help
Sep 30, 2007 | Miele Vacuums
AEG 6600 Bagged Canister Vacuum Logo
55 people viewed this question
Top AEG Vacuums Experts
Marvin
Marvin
Are you an AEG Vacuum Expert? Answer questions, earn points and help others
