Question about Facebook Social Network
Problems logging out
HOW DO U LOG OUT!!!!!!!!!!!???????????????????
    Scholar:
  • 72 Answers
In the upper right hand corner, click the Account dropdown, and "logout."
Posted on Aug 02, 2010
    Brigadier General:
  • 7,191 Answers
To log out of your Facebook account, kindly click the 'Account' tab at the top-right of the Facebook page and then select 'Logout' from the drop-down menu. (See attached image)
Hope this solves your problem. Thanks for using FixYa.
Log 10,000 - log 1,000 divided by 4 log 1.0125 = 46.34 I cannot enter this into my calculator and get 46.34 as in the example. is there a trick in the way to enter this? I have a TI-30X calculator....
Is the original problem (log 10,000 - log 1,000) / (4 log 1.0125) ? If so, press
( 1 0 0 0 0 LOG - 1 0 0 0 LOG ) / ( 4 * 1 . 0 1 2 5 LOG =
and you should see the expected result.
Jul 25, 2011 | Office Equipment & Supplies
When I substract log(2) from log(4) I get .301029957, the answer should be 2, what is wrong?
The answer for the problem log(4) - log(2) is actually 0.301, so the good news is that your calculator is working properly! Here's a quick breakdown of the solution for the problem:
1) We know that log(x) = N means that 10^N = x. So in this case, we need to find a number that 10 can be raised to in order to get 4 and 2.
2) To get a better idea of what the answer to the problem will be, we look at the scale of the numbers. 4 and 2 are both smaller than 10. In order to raise any number to a power and get a smaller number, that power must be less than 1. If the power was 1 or greater, the answer would be more than 10. Therefore, we know that log(4) is a decimal less than 1 and log(2) is a decimal less than 1.
3) Now we'll simplify the problem. A logarithm rule states that:
log(x) - log(y) = log(x/y)
We can use this rule to simplify the equation in the problem.
log(4) - log(2) = log(4/2)
Since 4/2 = 2,
log(4) - log(2) = log(4/2) = log(2)
4) Now to solve the equation, the only thing that must be calculated is log(2). This would be done on a calculator. In step 2, we analyzed that log(2) must be less than 1. Therefore, the calculator is correct with the answer 0.301.
Hope this helped!
Nov 30, 2010 | Texas Instruments TI-84 Plus Calculator
How do i do log base x problems (other than log base 10) on the datexx ds 883?
Calculate it the same way as on most other calculators, using the relation
log_b(x) = log(x)/log(b) = ln(x)/ln(b)
In words, calculate the log base 10 of x divided by the log base 10 of the base. You can also use the natural log function instead of the common (base 10) log--just be consistent.
Oct 19, 2010 | DateXX DS-883 Calculator
How do I find the log button or how do I use the calculator to calculate a log problem? i.e. (log (learning curve))/(log(2))
The natural log is the LN key, located just to the left of the 7 key.
To calculate the common log, use the relationship log(x) = ln(x)/ln(10).
To calculate the natural log of 3, press 3 LN
To calculate the common log of 3, press 3 LN / 1 0 LN =
Aug 09, 2010 | Texas Instruments BA-II Plus Calculator
I need help with a change of base formula problem.
It's simple here some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
you just need to know that the default base of log in calculators is 10, so log x mean
log x base 10 = log x / log 10,
so write log x / log y for log x base y example:
log 8 base 2 = log 8 / log 2 that is how you write it on calculator, hope it was helpful
Jul 01, 2009 | Texas Instruments TI-83 Plus Calculator
To solve the problem using log
Look the calculators has a default base 10 and you can't change it but you may learn this:
so instead input log 8 base 2 you need to input log 8 / log 2
your example answer is about 0.919... if i get right what did you write.
Glad to help :)
Feb 21, 2009 | HP 33s Calculator
How do i perform the calculation of log (base 2) 8? The answer should be 3....that is it is the inverse calculation of 2 cubed =8. Can any one help with the log calculation?
Yes look you can't enter the base in calculators it's default 10 so use:
so instead of log 8 base 2 input log 8 / log 2 it's easy
hope you understand :)
Feb 21, 2009 | Sharp EL-531VB Calculator
Can't chang the logbase
It's 2*3=6 but about the base, you can't change it in the calculators the default base it's 10 so log x it's Logbase 10^x here some logs:
in your example log 9 base 3 = log 9 / log 3 etc.
hope you get it, and it was helpful
Nov 12, 2008 | Texas Instruments TI-89 Calculator
Using logs
Here something that would help you:
so log 24 base 2 it's log 24 / log 2 etc.
and if i get right what you wrote x= 10 ^ ( 3 * (log 5) ) if no inverse it it's easy really Hope it's helped you.
Oct 23, 2008 | Casio FX-260 Calculator
Facebook Social Network Logo
80 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Sunil Pratap Singh
Sunil Pratap Singh
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
