Question about GE JVM1650SH Microwave Oven
I have a GE 1650 black microwave and is not heating anything. I heated a potato and after it was finished, the microwave went off. Thought maybe a fuse, but not is goes on though nothing is being heated. What can the problem be? Thanks
Espringst - this is Vikki with GE. I would not recommend you disassembling the microwave and trying to do any diagnosis yourself. A qualified service technician really needs to check the unit out. The microwave contains a capaciter that retains power even when the unit is unplugged which makes it unsafe for the do-it-yourselfer to try and fix. Please call svc to check it out.
Posted on Aug 02, 2010
  • GE Master
  • 17,130 Answers
It is possible that your magetron is not working.First of all disconnect the power, open the top,if you had checked the fuse to be good then check the high voltage power capacitor and teh wores to the magnetron. If all these seems fine then a voltge check must be made when the set works in microwave mode. Put in a cup of wter and switch on. If the relay does not click along with the fan coming on , then the relay circuit must be checked. If you are not familiar please take help as it is dangerous to probe without any klnowledge. I am sure there cannot be anything serious than a failure of the one of these. hope my advice helps you out. Good day
How to heat cooked potatoes for mashed potatoes
hi Judy.
Put in the large pot as you peel and slice so they don't turn brown. Be sure water covers the potatoes by 2 inches, on medium-high heat and bring to a boil. Reduce to medium-low heat, cook the potatoes for 20 minutes until the potatoes are soft and fork tender. Turn off the heat, and drain well in a colander.24 Nov 2015
Make Ahead Mashed Potatoes Reheated 5 Ways - Delicious Table
https://www.delicioustable.com/make-ahead-mashed-potatoes-reheated-5-ways/
if you want to know more go to this link.
How to heat cooked potatoes for mashed potatoes Google Search
Nov 23, 2017 | Microwave Ovens
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
Ge jvm1870 it won't heat anything, all other items work
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwave oven.
Mar 03, 2009 | GE JVM1870 Microwave Oven
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Nov 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat and mkes a sparking sound 8-11-08
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
If you need further help, please reply back with your brand and model number so we can help you.
Aug 12, 2008 | GE JEB1095 Convection/Microwave Oven
I bought a ge microwave 5/20/08. I have used it several times and it has worked well. Today I was cooking baked potatoes. I usually do them 1 by 1 and then put them in the oven for a crip skin. After...
It should default to the high power level without your having to select that.
But if you think it may have a problem, you could unplug it for a few minutes then plug it back in and try again.
After that, if it's not acting as it should according to the owner's manual, it may need service.
If so, since it's under warranty, I would let GE fix it.GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | GE Microwave Ovens
Slow turn, hot food
underneath the deck is a geared motor that turns the platter. check for non lubricated bearings or slipping gears.
Aug 22, 2007 | GE JVM1440 Microwave Oven
GE JVM1650SH Microwave Oven Logo
111 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
