Question about Cell Phones
My on off rubber button is not functioning please assist me
  • Cell Phones Master
  • 17,130 Answers
Remove off the front panel and check on the panel for dirt. It is possible that there is smudging on the board.clean and set the rubber pads whose bottom side had been cleaned with methyl spirit. Since there is functioning of the other buttons there will not be much of an issue then to get this done. Hope this helps. Good day
Posted on Aug 02, 2010
Hello dear yamaha psr e413 not work some button switch.so, i did carbon past. but not work. please help me. dear. Thank you.
Lets answer the question. Which button is not working? It normally means as suggested either the carbon under the rubber button is worn or in some cases the circuit board is damaged or worn. Try to replace the button first as the cheapest option. Report which button and I can send you details of the part number needed either by number on the attached or by which function it does eg tempo + / -
Apr 20, 2017 | Yamaha Music
Scanner is stuck @ bank 1, ch.16 @ freq.155.5800 and wont bugd . HELP ME PLEASE
If no buttons are responding it is quite possilble that a button is physically stuck (when you depress one button and hold it, no other buttons will function). Press and wiggle EVERY button to see if perhaps one is jammed. Rubber buttons especially can get caught under the surrounding plastic.
Let me know if that works.
Jun 28, 2011 | Radio Shack Pro-95 Handheld Scanner
The buttons on my ipod classic (30gb model) don't work properly
font.f1 { font: 12px Helvetic Thanks for asking your question with Fixya Support. I will be glad to assist you.
Anytime your iPod's mechanical functionality is not where it should be, the easiest way to restore the device's button operations, is to either perform a restore
Or attempt to reset your iPod:
• Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
• Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. If it does not work the first time, you may have to repeat this process.
To acquire more troubleshooting options to regain operational capacity of your iPod Classic,
I have included the link from Apple for your model of iPod.
iPod (5th Gen) Troubleshooting Assistant
These processes should help restore the button functions on your iPod Classic.
I hope this helps. If it does not, please feel free to reply back to this post, I am always glad
to assist.
Regards,
-Mactechtrainer
Mar 19, 2011 | Apple iPod classic 5th Generation
How to delete unwanted Shortcut numbers form Lexmark x642e?
If the printer is connected to a network, type the IP address of your printer on the address bar of your web browser. On the printers web interface, click on Configuration and select Security. Click on Function access and select a specific function of the printer, click the drop down button and select function disabled and the click submit.
You may also use the printer operator panel. Click on Menu button >Settings > General Settings> Home Screen customization > select the specific function and select do not display and click on submit.
For further assistance, please contact Lexmark Technical Support.
Jan 15, 2011 | Lexmark X642e All-In-One Laser Printer
The scan function won't work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated.
the scan function won\'t work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated
Dec 03, 2010 | HP DeskJet F4280 All In One Printer InkJet
My psps x o and square and triangle buttons stopped working.... Can anyone tell me how to fix this problem......
This is because behind the button there will be a rubbers placed in it.These are the rubbers which press against the circuit board and does the function specified for that button.May be this rubber got damaged so need to replace it.Better take it to the service centre and they will do for you.
Thank You
Sep 06, 2010 | Video Game Consoles & Games
The + volume button is not reponding
if all the buttons are working and only this one isn't working then there's something wrong with how it functions. does the button have a double function?
Jun 11, 2010 | Samsung TV Remote Control
I have a toshiba ct 9939 remote. the buttons have lost sensitivity. how do i open the remote to clean the contacts?
Check for and remove any screw(s) in the battery compartment. Then try gently prying the two sections apart. When seperated remember where the rubber buttons (buttons are usually one single, rubber like, pad) were seated (most the buttons will only fit one way, or you will remember where they were located just by looking at it). on the remaining cicuitboard in the other half of the casing, you will see numurous black dots, these are what the rubber buttons push to make the connection that will execute the command you are trying to give your tv. With a q-tip, slightly moist (no cleaning agents!), gently brush these black dots a few times. Gently rinse the rubber (buttons) pad under luke warm water ( no cleaning agents!) taking detail to the underside. A slight cleaning will be plenty to improve the functioning of the remote. Make sure to let the parts COMPLETELY DRY before installing them back in the remote!
If this helped you (or not ), please rate, thank you!
Feb 03, 2010 | Toshiba Televison & Video
Paper tape in my TI 5045, please.
Feed the paper in the back press the paper advance button while pushing the paper in the rear slot, and it should feed the paper through.
Hope this helps.
Good luck.
Mac
Feb 08, 2008 | Texas Instruments TI-5045 SVC Calculator
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
