Question about Kenmore HE2 Plus Front Load Washer
Sud error comes on sreen - Kenmore HE2 Plus Front Load Washer
  • 5,081 Answers
If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
Posted on Aug 02, 2010
I have a Whirlpool 9500TC Front Loader Washer. Can't wash garments due SUDS Display. Can't use any washer functions due to SUDS display.
Run a cycle with white vinegar this will clear the suds. Make sure you are using HE soap if not the unit will over suds.
Another common issue is the drain pump filter. If it gets clogged the sud error will come up as well. If you have water inside the pump may need to be cleaned. Simply remove the three screws ont he bottom of the lower access panel and then twist the handle on the filter. If water is inside the washer, it will come out when the filter is pulled out.
Good luck with your washer repair friend.
May 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does SUD mean
"SUD" is a Suds Detect error code. The washer will not complete any cycle as long as the error code is present. The following link explains the error and some potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error comes from using too much, or the wrong type, of detergent. You are required to use High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any manufacturer warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds is NORMAL and preferred.
If you use too much detergent, using the RINSE/SPIN option is recommended to flush the tub, drain pump and lines. IMPORTANT: It can sometimes take SEVERAL cycles to clear. Also, leaving the door open for a while can allow air into a suds filled drum to get rid of some of the bubbles.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it from time to time to troubleshoot your washer.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code 5ud or Sud
The front panel is displaying "SUD". This is a Suds Detect error code. The washer will not complete any cycle as long as the error code is present. The following link explains the error and some potential causes:
If too much deteregent has been used, using the RINSE/SPIN is recommended to flush the tub, drain pump and lines. IMPORTANT: It can sometimes take several cycles to clear. Also, leaving the door open for a while can allow air into a suds filled drum to get rid of some of the bubbles.
Jun 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin, Display showing (Sud)
May 24, 2010 | Kenmore Front Load Washer
Suds
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud setting, machine will not advance
"SUD" is a Suds Detect error code. The following link explains the error and some potential causes:
The number one cause of the error comes from using too much, or the wrong type of detergent. You are required to use High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
May 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing SUD
May 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Display shows sud
"SUD" is a Suds Detect error code. The following link explains the error and potential causes:
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
Read through the link provided and let me know if you still have questions. I hope this helps you.
Apr 22, 2010 | Kenmore 45087 Front Load Washer
Sud
This is a Suds Detect error code. The following link explains the error and potential causes:
Apr 22, 2010 | Kenmore Elite HE4 Electric Dryer
F 02 ERROR
Try cycling the washer a few times without a very small load of clothes and no detergent. I assume that you are and have beenm using only HE type detergent and I suggest you try using about 1/2 to 1/3 the amount called for until your system is purged of any and all remaining detergent in the lines. Here are the manufacturers reccommendations to address your problem..
“SUD” (Suds Routine)
When excessive suds are detected, a suds routine
automatically starts. This routine removes extra suds and
assures proper rinsing of your garments. “SUD” is displayed
during rinsing and at the end of the cycle to inform you that
Suds Routine was activated. Use only HE (High Efficiency)
detergents.
Hope this helps you..
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
81 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
