Question about Microsoft Windows XP Professional for PC
NOT RUNNING PROPERLY - Microsoft Windows XP Professional for PC
    Guru:
  • 561 Answers
Check your hardisk
Posted on Aug 02, 2010
My cusinart pro custom 11 the machine is running but the blade is not spinning not even manually
Have you attached everything properly?
They have a safety feature that keeps them from running when the basket and top are not attached or not attached properly.
Nov 28, 2015 | Food Processors
Headlight wiring low voltage
A battery's voltage is properly tested under load. This sounds like your battery is low on fluid or has not been charging properly. Not charging properly could be from low battery fluid, poor cable connections or a failing alternator. You did not state whether you tested this voltage issue with the vehicle running or not. If the vehicle was running when you observed this change in voltage upon turning on the headlights, then a bad alternator is most certainly suspect.
Aug 26, 2012 | 2004 Toyota Sequoia
Do not know cubic size. It is a side by side approx 10 years. Motor is running but coil is freezing up in freezer, refrig side is not cooling. Evaporator fan not running so changed evaprorator motor. Fan...
The problem is still from the fan, try to settle down and try to connect the wire properly. if the wire is fix properly fan will work and refrigerator will also work.
Goodluck
Jun 28, 2010 | Amana SXD524VW Side by Side Refrigerator
Freezer FZ175 Red Warning Light is flashing
The flashing red light indicates the problem in the temperature of the unit.The temperature is rising over then required so the red light is flashing. There are some possibilities that you will have to get checked.
1) Make sure your freezer/refrigerator door is closing properly and sealing all around.If the doors are not closing properly then this can lead to rise in temperature.
2) If doors are proper and closed properly then other possibility is to check the compressor .Check the compressor is it running properly or its not running.Beside the compressor there is a fan if the fan is running the compressor is turning on if fan is not running the compressor is not running.If the unit is not getting very cold this also indicates the problem is in the compressor section.A weak or faulty compressor causes the temperature rise problem.
3) If compressor also checks out ok then the other possibility is fault in the thermostat of the unit.The thermostat is getting overheated and this is causing the red light flashing.
4) Before replacing any part in the unit try the defrost procedure first .Keep the unit unplugged from power and keep both the freezer/refrigerator doors open .let it remain unplugged for 24 hours.Then reconnect the power and check for some time.If the unit works properly that means defrost procedure solved the problem.But if same error light comes On flashing that means the faulty part needs replacement.
You can get required parts for your refrigerator from the on-line sites like :--
www.partsselect.com.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 04, 2010 | Refrigerators
When the engine is hot the check engine light came on and the fan (is ok ) don't start
Hi:
How hot is it getting? Is it running hot? Is there water in it or is there a water leak? You may even have a stuck thermostat. How many fans does it have? What makes you think that the fan is working properly I mean if the air conditioner is on when it's running the fan (s) will run automatically, make sure the air isn't on when trying to see if the fan is working properly while the engine is running. Those fans comes on by use of a mercury thermal switch that is mounted in the water jacket in some cars. If the fan is workinf properly and the engine is overheating then it could be something as simple as very low water in the cooling system, if it's full and the fan is working properly you may have a bad thermostat.
Hope helpful
Don
dwhitehead4062@verizon.net
May 02, 2009 | 1995 Ford Escort
Refrigerator operates properly for a few days then stops working
When you said it stopped working, do you mean it is not working at all? or is it not cold enough? If not working at all, that will be thermostat, when you change the thermostat, did you adjust the small switches to match you unit and make sure wires are connected properly, If not, it would work properly. If not cold enough, check and make sure the condenser fan motor and compressor are running, if both are running but not cooling then you have sealed system problem.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
Program not running properly
Have you tried getting another installer of that same application? Maybe it is not complete and that is why it is not running properly.
Nov 05, 2008 | Computers & Internet
Car running hot
If the fan is working properly then you might want to check the INTAKE MANIFOLD for leaks or make sure the HEAD GASKET isn't blown. If the fan is NOT working properly, replace the fan and the pigtail that connects to it
Aug 11, 2008 | 2001 Ford Crown Victoria
Microsoft Windows XP Professional for PC Logo
15 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
