Question about Nikon 105mm f2.8 G ED AF-S VR Micro Lens
My nikon 105mm VR AS F2.8 makes a strange noise while focus and then after i remove my finger from the shutter it make a click noise as well ? is that a problem ?
  • Nikon Master
  • 17,130 Answers
As far as your focus is happening htere is no case to worrry. If the camera is set to auto focus then while you point if the focus is set right , you can just ignore this case. However if the focussing is not perfect it is possible that there could be some dust dirt or sand particles in the system which incidentely must be looked into by opening the camera. the click could be that the focus is falling in line and as such need not worry much. Use the manual focus to extremes and try a gentle tap to get any such foreign particles out of the system. I would advice not to open the camerra unless there is a serious focus fault. Otherwise continue to make use for the best. Good day
Posted on Aug 02, 2010
  • edubyatx Feb 15, 2011
    I have the same noise. I assumed it was the VR operating.
Nikon D90: Won't focus properly in automatic mode
Make sure the subject is well lit. The autofocus relies on differences in contrast to determine proper focus. Move to a well lit area or add additional light and attempt again.
Make sure the aperture ring on the lens (if that lens has one on it) is set to minimum (highest number - f22 etc.) This value it often a different color ink than the others to help speed locating it. On most Nikon & compatible lenses, when the aperture is set to minimum, the camera's main & sub command (thumb and finger) dials will control the aperture and shutter speed. When the shutter is held down 1/2 way, the aperture will open fully (to allow the most light in and speed composition) and then automatically stop down to the commanded value when fully depressed for the exposure. If you have the aperture set on the lens to something different - it may be preventing sufficent light from entering and interfere with the autofocus function.
Apr 05, 2013 | Nikon D90 Digital Camera with 18-105mm...
I dropped two of my lenses and I thought everything was fine. But when I take the picture i can't tell what I'm focusing on. Also, when I take a picture my lens makes a squeaky/scratchy noise.
Lenses have precision mechanisms and alignment of lens elements. If damaged, you should have them serviced by factory authorized repair centers. A lens damaged due to falling or impact will not be covered by warranty - however if under warranty and the work is performed by an unauthorized party, the remainder of any warranty will likely be void.
If the lenses are Nikor or Nikon, you should check the Nikon Service and Repair page. You can get an estimate by providing the information requested on that page.
I chose an "AF-S DX NIKKOR 18-105mm f3.5-5.6 ED VR" (your lens may be different) and listed it as dropped an got an estimate of $199 for repair.
I hope this helps & good luck!
Nov 15, 2012 | Nikon D90 Digital Camera with 18-105mm...
I set this "Nikon 105mm f/2.8G ED-IF AF-S VR Micro-Nikkor Lens" or tried to set it to F2.8 in full manual mode. the F-Stop wandered from F2.8 to F3 / F4.5 depending on where i pointed the lens. I...
You have described Aperture priority mode: you set the f/stop and the shutter speed changes to make the exposure correct.
Full manual mode requires you to set both the shutter speed and the f/stop. You are seeing the recommended f/stop for the shutter speed you have selected.
Sep 25, 2010 | Nikon 105mm f/2.8G ED-IF AF-S VR...
Got my Nikon d90 for 3 months now,but encountering error problem with my Nikon D90 w/ 18 105 vr lens.sometimes when i'm ready to shot it appears on the Top LCD,error F--,..Pls. help guys...Thanks
This is a common problem with this camera/lens conbo. I "solved" it by removing the lens, then reinstalling it - but hold the lens release button down, and rotate the lens a nuber of times (in the camera body) before releasing the button. It appears that the issue is poor electrical contact between the lens and camera body. If there is a poor contact, the camera will not know if thereis a focus and will lock the shutter release. With this poos contact, the camera will only fucntion in manual mode
Hope that this helps
Aug 31, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Sep 01, 2009 | Nikon D5000 Digital Camera
Lens will not open up all the way
Is the maximum available aperture dependent on the focus distance? Many macro/micro lenses "dim" slightly as you focus in close.
See if you get 2.8 focused at infinity.
May 22, 2009 | Nikon Telephoto AF Micro Nikkor 105mm...
Sigma 70-300 Macro Motorised Lens for Nikon has stopped autofocus
If you just purchased the lens I would take it back sounds like the lens is jarred and defective should still be on warranty
Jan 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
55-200mm VR focus noise
The lenses have a focus motor built into them.when the camera is set to auto focus, once you press the shutter button, the motor activates to set the correct focus. VR is for motion stabilization. Turn off AF on lenses and camera and see if noise stops.
Dec 12, 2017 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Nikon 105mm f2.8 G ED AF-S VR  Micro Lens Logo
325 people viewed this question
Top Nikon Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Nikon Home Security Expert? Answer questions, earn points and help others
