Question about GT Bicycles Gt I Drive Eccentric Bearings 216h
I have a 2009 GT Marathon Sport. I like the bike...I would like it a lot more if the gears didn't constantly go wonky and skip back and forth between gears, especially when I am trying to power up a hill. If I can't get this figured out, I know a 2009 GT Marathon that will be hitting Craig's List. Is this typical for the I-Drive that everyone raves about??
  • GT Bicycles Master
  • 1,272 Answers
No, it's not typical, but there are a variety of reasons that you may be having a problem, including gear selection when climbing, riding technique, a shift cable problem or simple adjustment, and it would be very difficult to diagnose through the Internet. I would strongly advise you to get help from a knowledgeable friend, a bike co-op or a bike shop. A diagnosis at a bike shop should be available at no charge.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Posted on Sep 29, 2017
My speedo went crazy one day and now it displays insanely high numbers when standing still after turning the ignition on and then goes to 0 mph constantly when actually being ridden.
Hi, Luke for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Reiju, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Rieju MRT 50 MOTOVLOG SPEEDO STOPS WORKING
How to fix motorbike speedo No speedo cable
Rieju Motor AM6 Engine Workshop Service Repair Manual Download Manuals... $15
Official Genuine Rieju Parts store Frequently Asked Questions RIEJU Marathon 125 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 29, 2018 | 2011 Rieju Marathon 125
Someone dropped my motorcycle while it was parked in the street Apparently they wanted to take a picture on it and managed to drop it Since then I had a variety of problems some which are probably not...
Probably a stuck needle valve Float. Your engine is flooding on one side bogging it down. Depending on your carbs it could be a bent constant velocity rod/pin (same thing really). The racket may be coming from the bad carb trying to stabilize with a bent rod.
Apr 15, 2014 | Cars & Trucks
My chain has gone to tight and it locked in gear
Try rolling the bike back and forth while trying to take it out of gear if this doesn't work ur clutch has brine burned out and ha s locked ur gears up but this one would be the last thing to check once u have tryed rolling it.
Aug 12, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
Gear selector shaft replacement
take off gear selector remove kickstart drain oil cooling system take back brake pedal off undo outer casing remove casing take clutch n hub out remove shaft an reverse procedre hope this helps u
Mar 05, 2012 | 2009 KTM 250 SXF
From 4 gear to 7 gear every 6 to 7 pedal it skips like changing gear mountain bike
Hi michaelcook1....
Sounds like you need to adjust your derailer on the back of the bike, it may be out of adjustment and causing the chain to slip.
Please take time to rate me
Aug 18, 2011 | Cycling
IJust bought a 2009 Motobecane Cafe Latte Hybrid bike used. The previous owner hardly used the bike and it looks new. He stated the bike probably need a tune up and the front derailleur was skipping the...
The derailleur has to be properly aligned to the chainwheels, then adjusted properly. A new cable must be installed correctly so that there is not excess friction, and then given the right tension. If that is done then the problem may be the shifter. If when you shift from the large chainwheel a single click sends it to the smallest then the shifter is possibly broken. You can try squirting wd-40 or similar into it to see if it's gummed up.
Mar 18, 2017 | Motobecane Cafe Latte
I have a pivot bearing problem with my Marathon GT....feels like the back tire is loose as hell, and can be wiggled side to side, with way too much play . You can see a gap in the frame when it moves....
You don't say what year the bike is... but quite common for bearings to show wear after a few years. Just replace it... you may be able to choose stainless or ceramic but generally I just use a quality steel bearing. It's a simple job IMHO, Youtube will probably have a video of someone doing it. But you may need a special tool to get the bearing out without damaging the frame.
Oct 02, 2017 | GT Marathon Carbon Expert
I've got a 21 speed bike and I get a skipping ,
It is the derailer (the part on the back that the chain runs through). Take it to a bike shop or bike enthusiast. The repair should only take about 5 min. Some bike shops won't even charge you.
Jul 22, 2011 | Cycling
Seems chain is loose. every 3 pedel in skips and recatches sprocket. could be trying to change gears but doesn't look like it is, think its just loose. huffy nightstalker 12 speed
Sometimes chains have stiff spots that cause them to skip. You can try checking the chain for stiff spots or just spray some lube on it and see if it loosens up. If you turn the bike upside down or put it such that you can let the back wheel spin freely, you can slowly turn the pedal and see if you can see the spot on the chain where it slips. If you find it, you can spray lube on the spot and work it back and forth until it's loose. Good luck and hope this works!
Mar 14, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
GT Bicycles Gt I Drive Eccentric Bearings 216h Logo
348 people viewed this question
Top GT Bicycles Cycling Experts
Michial Gueffroy
Ed Hauk
Ed Hauk
Level 1 Expert
Donald Ayers-Marsh
Are you a GT Bicycles Cycling Expert? Answer questions, earn points and help others
