Question about Video Game Consoles & Games
I have a pair of earphones that needs repair the colors are red and copper witch one is positive?
    Scholar:
  • 72 Answers
Red is positive.
Posted on Aug 02, 2010
What colour wire does what with Samsung in ear earphones
This is an educated guess.
You should have 4 rings around your 3.5mm connector. From the tip to the base of the connector....
#1 - left audio - Black
#2 - right audio - Red
#3 - Ground - bare copper
4# - Mic/volume - green/brown
The wires for the left and right channels (pins 1 and 2) and the ground, (pin 3) should run from the connector through the volume control, to each ear piece. The mic/volume wire should terminate at that control. although it could connect to more than one place within the control.
You may be able to open the volume control, gently, and see which wire stops there and which continue on through.
I hope this gives you enough information to complete your project.
Dennis
Apr 22, 2014 | SAMSUNG EHS64AVFWE Stereo 3.5mm White...
HOW TO WIRE A CEILING FAN TO WIRES IN CEILING WITCH WIRES CONTENT TO WITCH ONE
Without knowing the make & model of your ceiling fan, I can't answer exactly, but I'll do my best.
You probably have black, white & green wires. Green is always ground, which means it gets attached to the metal box or ground wire you are connecting to.
Since you're connecting (presumably) to an AC current, you should try to connect black to black and white to white. If you have some other colors, it shouldn't really matter.
HOWEVER! If you're connecting aluminum to copper wire, you should not use the regular wire nuts. Copper is much softer than aluminum. Instead of winding around each other, which holds the wires well, the copper will wind around the aluminum.
This means the copper could slip off the aluminum, exposing wires. (translation: BAD THING!!)
Copper + aluminum = No wire hangers... err.... No wire nuts.
Sep 06, 2013 | Computers & Internet
, 1-need schematic to rewire a lorex color camera model no:MC7555R i have five wires coming out the back of the camera 1'
The RED wire is your 12 volt power "positive". The BLACK wire is your 12 volt power "negitive" The YELLOW wire is your camera video. The white wire is your cameras audio & the copper wire is shielded ground.{Davesajak}
May 01, 2012 | Lorex SG6153 / Weather Resistant Mini...
I bought some halo driving lights for my '03 GMC Sierra 1500, they came with a wiring harness, switch and everything needed for installation except for installation instructions. Help PLEASE!
Tools recommended for this job: wire stripper, wire crimper, volt meter, 4x quick wire connectors, 4x male crimp connectors, 4x female crimp connectors
  1. First, tape the halo and/or LED wires to the back of the headlights to keep them from tangling.
  2. Keep the pairs in order by their color, e.g. black, black (ground) and Red, Red (positive). Note: positive and ground wires might not always be black and red.
  3. Remove some of the plastic shielding at the end of the wires to expose enough copper wire, next twist the copper together to strengthen it.
  4. Shove the twisted copper into a crimp connector; crimp the location where wire and the connector end overlaps, wrap with electrical tape to secure it.
  5. Two extra wires in black and red will be helpful to make the halo/LED wire longer to easier installation. Remove shielding: show copper: use the connectors: connect the positive and ground from the headlights.
  6. Next step, turn the headlights inside the car to the [on] position.
  7. Take the volt meter and connect the negative to the negative on the battery (please use extreme precaution when doing so).
  8. The headlight harness usually will have [3] wires, generally red, black, green (headlights, ground, turn signal). Use the volt meter to test which wire will have power running through it (since the headlight is in the [on] position) which will be the headlight wire.
  9. Use the quick connector to connect the extra wires (red) to the power wire on the harness and black to the ground. This will split the current coming from the harness. Crimp the connectors and use electrical tape to secure it.
  10. Now connect the projector headlight halo wires and the harness from the car.
  11. No wires should be left over unconnected.
  12. The installation is now complete.
Jan 14, 2011 | GMC Sierra 1500 Cars & Trucks
Need to find out which is the proper speaker wires for hook up yellow to tweeter or sub? And striped one is positive or negative?
You can probably trace which colors go to the smaller of the amps... Yellow is often used for tweeter but there really is no standard. Striped wire is probably the minus lead. If a pair is heavier, that would be the pair for the woofer... and red is often positive for woofer and black the minus. Searching the Mackie schematics doesn't really show colors. You could call their service dept.
Dec 14, 2010 | Mackie Th15a Power Speaker Pair 15 Two Way...
Need the speaker color code
speaker wires on factory harnesses are usually paired. u should have wires red,black,blue and yellow witch are for the radio the the other 8 wires are for the speakers usually a solid color and the other of the same color with a stripe on it
Jan 25, 2010 | 1994 Jeep Grand Cherokee
Left earphone has snapped off a pair off
You can try to re-solder it but make sure you use a heat-sink and flux. The problem with small earphones is that it's a wire within a wire - for visual purposes picture it like the coax cable that goes in the back of your TV. If the inner wire is missing you can't just strip the wire to get it out because you need to keep the two from touching. If you don't mind spending a small amount of money take it to your local electronics repair store and they'll reconnect it for a small fee.
Happy Holidays and good luck!
Dec 18, 2009 | Ultimate Ears super.fi 5 Pro Consumer...
Speaker wire leads
i simply used my brain and hooked the copper wire to positive(red), and the silver wire to negative(black), being that the colors are similar. works fine.
Dec 13, 2009 | Power Acoustik NB-2 Car Tweeter
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
Need wiring diagrams for headset
I have the circuitry guide for the DSP box. I'm going to consider the top of the board the part with five connections, and the bottom is the part with eight connections.
From left to right on the top, the insulation colors are: red, white, green, black, no insulation.
From the left to right on the bottom, the insulation colors are: white, copper, copper/green, blue/green, red/green, red, copper/blue, green.
May 24, 2007 | Plantronics GameCom Pro 1 Headset
Video Game Consoles & Games Logo
14 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
