Question about Lanzar HTG2600D Car Audio Amplifier
Lanzar htg2600d protect mode
Goeson protect mode when turmd on replaced all caps and fan when replaced too i hear a clicking but wont come on maybe a part that meed to change i ordered all caps from lanzar with the fan
SOURCE: my amp wont go past protect mode
I had the same problem. be sure to change all transistors cause once one goes the rest useally goes right along with it... replaceing one or two transistors will not do the trick, cause once you power up again the rest of them will go, & you will have to repeat the prosses
Posted on Nov 25, 2008
etirbynnor
  • 655 Answers
SOURCE: lanzar amp 1000 watt stays on protect mode
Hello snow11879,
I haven't been able to locate any support information online about your product, other than the email contact for support questions:
support@lanzar.com
If the amp stays in protect mode all of the time, I would suspect a short in the speaker wiring or speaker(s) voice coil(s), or perhaps a faulty ground. If it plays for a short period of time and then goes into protect mode, it is most likely overheating. First check all of the wiring. Test your speakers on a known good amp and make sure there are no places in your wiring where the insulation may have been damaged, causing an intermittent problem.
Many owners have reported that this particular amp has a tendency to overheat. Also, when run in bridged mode, the speaker impedance needs to be at least 4 ohms. It will overheat if the impedance is below 4 ohms.
Hope this helps.
Posted on Apr 18, 2009
  • 6 Answers
SOURCE: lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Posted on Aug 01, 2009
SOURCE: lanzar vibe 1500 protect mode
well it s getting power, but nothing is kicking out plus the green nor red lite is on
Posted on Apr 09, 2010
gotthebeats
  • 11 Answers
SOURCE: installed lanzar 266 amp yesterday
most commonly that means that somewhere there was an arc in the electrical either the pos or neg going into the amp or rcas or its the speaker wire from the amp to to the sub itself look especially for little wires touching opposit polarity wire (like a little +wire has moved and touched a - wire)
Posted on Oct 12, 2010
Lanzar vibe266 2000 watt stays in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
.A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-vibe266-2000-watt-stays-in-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Feb 05, 2013 | Lanzar VIBE266 Car Audio Amplifier
I have a Lanzar 4000 watt amplifier hooked up to 2 12inch MA Audio subs. When I crank my car the green power light on the amplifier comes on, but after a second or two it changes to protection mode. I have...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get an old school Opti Drive. .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-4000-watt-amplifier-hooked-up-2-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jan 29, 2011 | Lanzar VIBE286 Car Audio Amplifier
I have a Lanzar HTG2600D amp, Iv hooked up systems for years so its not the obvious. The green light is on, everything it hooked up, the fan is running but there is no sound. I pulled the base cover off...
did you run direct to the speakers or to the rear of the radio to split factory wiring. Check to make sure that you are connected to the correct side of the wiring behind the radio. If that is correct, then check the input of the amp. Try a different source and see if you get signal. Make sure your wiring is not crimped.
I use my ipod and hook it to an 1/8" x RCA splitter and plug direct in the amp. try to isolate the amp as much as possible. 1 speaker to outputs and 1 source you know works. Then test from there.
Jan 06, 2011 | Lanzar HTG2600D Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
Lanzar amp 1000 watt stays on protect mode
Hello snow11879,
support@lanzar.com
Hope this helps.
Apr 18, 2009 | Lanzar VIBE266 Car Audio Amplifier
Protection mode?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check your connections. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-mode-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
May 25, 2008 | Lanzar Car Audio & Video
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Protection mode on Lanzar Vibe 241
Almost without exception, if the protection light comes on as soon as you power it up, the output transistors are defective. Any reputable repair shop that services car audio equipment should be able to repair it.
Oct 06, 2007 | Lanzar VIBE241 Car Audio Amplifier
Lanzar vibe 1500 protect mode
sorry bath your problem is a proablem the soft
Aug 02, 2007 | Lanzar Vibe 1500D Car Audio Amplifier
My amp wont go past protect mode
Disconnect all speaker wires and signal cables from the amp. If it powers up (no protect light), the wiring needs to be checked. If it still shuts down (goes into protect), the amp likely has blown output transistors.
Dec 01, 2006 | Lanzar Vibe 218 Car Audio Amplifier
Lanzar HTG2600D Car Audio Amplifier Logo
21 people viewed this question
Top Lanzar Car Audio & Video Experts
Morne Olivier
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
