Question about Sanyo 42K30E 42 in. TV
Black spots on sanyo tv screen . sons girlfriend thinks possibly someone put a magnet by the screen in multiple places. unsure what happened..
2 Suggested Answers
saryejade
SOURCE: No sound and black screen
lets get together, start a list of names and sue companies selling crappy wares at way too high prices! email saryejade@aol.com
Posted on Oct 05, 2012
Sanyo dp42848 black spots and scrambled screen
Black spot means the LCD panel is faulty. Its better to go for new tv than rearing this one.
www.electro-medical.blogspot.com
Oct 07, 2015 | Sanyo DP42848 LCD TV
My son put a magnet on the screen of his InnoTab2. Now it has a blank spot on the screen where the magnet was. Is there any way to repair this?
LCD displays are not affected by magnetic fields like CRT displays are. It sounds like the display might have been damaged by hitting it with the magnet and if this is the case the display will need to be replaced.
Dec 31, 2014 | Televison & Video
Sanyo hd flat screen tv loosing color can it be repaired
It should be replaced with a new one. Normally these type of faults are irreparable.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Screen faults & possible causes to LCD screen are given with illustrations.
Jul 29, 2014 | Sanyo Televison & Video
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
Can Magnetised tube be demagnetised
i have had this same problem before. turn the tv on and take a magnet and put it over the spot that is on the tv screen and try moving the magnet over the spot and then push it off the screen. you dont have to touch the magnet to screen you will see what to do when you do it hold it off the screen about a 1/16 to 1/4 inch off the screen and just keep moving it to the end off the sreen like you are pushing it off of it
Jan 25, 2013 | Televison & Video
Westinghouse LD-4695 led hdtv bought it less then a month ago and its showing white cloudy spots around edges to pictures of it and they came out blue idk if its because the home theater speakers were all...
Depending on how big your speakers are and how they were to the TV....that might be the reason. Magnets are the worst thing you can have next to electronics. It either that, or you bought a lemon, or you have a kid in the house and they put magnets on the tv for fun.
Dec 15, 2012 | Westinghouse 46" LED TV HDTV 120Hz Full...
My tv has black splotches or pools on the bottom
If the splotches are a shawdowy black and look like mold growing between the Lens, its most likely dirt or water spots on the bottom of the large mirror. I cleaned mine and missed a few water spots on the bottom of the large mirror and the splotches (spots) showed on the screen. Other than Dirt, or water spots, There is nothing else that I can think of that would cause this. Unless the Someone has cleaned the screen and it soaked up between the lenes. But it Takes about 30 minutes to disassemnble, give it a good cleaning and put it back together.
Nov 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv rainbow in screen
The picture tube has become magnetized, possibly by someone getting a magnet to close to it. You can de-magnetize it using a strong magnet (cow magnet or similar). Place the magnet as close the the screen as possible without touching it to the screen. Starting at the middle of the screen and slowly (not too slow, about one full circle per second should do) move the magnet in a circular motion. With each full circle move the magent twards the outside (making a larger circle) as well as moving it farther away from the screen. Using a magnet will not harm the screen, so play with it and you'll soon get the feel and will see what you need to do.
Tv's have a circuit built in to 'Degauss' (demagnetize) the screen each time you turn it on, but this will only work if the set is 'Cold'. If the set is left off for 2 hours (to cool doen) and does not demagnetize when you turn it on the circuit is faulty.
Jul 21, 2008 | RCA TruFlat 27F520T 27" TV
My picture was distorted by a speaker magnet
well , yes , you have to purchase a DEGAUSSING COIL to take care of this problem and know how to use it (which its very easy) available at electronic stores (try EBAY) What you do is you place the DEGAUSSING COIL in front of the color spot and do circular motions while slowly stepping away from it . that should take care of that.
Apr 12, 2008 | Panasonic CT-34WX54 34" TV
A magnet touched my screen
My son touched my television screen with a magnet in two spots leaving two discolored areas on the screen,purple and green in hue. I read many quick solutions to this problem on the net and none seemed to work completely,so what i did is took the same magnet that touched the screen and held it in my fist,then with TV on i waved my fist all around the screen working from the spots outward to the edges and this worked completely! Hope this helps someone..
Apr 04, 2006 | Sanyo DS27800 27" TV
Sanyo 42K30E 42 in. TV Logo
313 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
