Question about Weiser Lock POWERBOLT ELEC DEADBOLT
How do I reprogram the entry code for weiser automatic powerbolt lock?
  • 1,557 Answers
  • Remove the inner cover plate from the lock.
  • Locate the small round reset button near the left side of the circuit board (Red or Black).
  • To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
best of luck.
Posted on Aug 02, 2010
  • papouducafe May 15, 2011
    First, I fix this problem after an hour of try.
    I conclude that this door lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
    I determinate that I put the third code by error the was i program it the firs time.
    I guide you...
    To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
    To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
    To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
I am looking for a manuals for a weiser lock powerbolt 1000 can i down lord
powerbolt 1000
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Apr 07, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
We lost the directions how do you change the code and how to get the back off
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
Dec 01, 2010 | Weiser Lock GED1460X3BR Lifetime Polished...
How do you reprogram after battery has died?
Nov 09, 2010 | Weiser Lock GED1460X3BR Lifetime Polished...
How do you reset all the codes on a weiser lock?
Oct 29, 2010 | Weiser Lock Powerbolt 1000 Lock
How do i program 2 differt codes and erase old codes
Oct 26, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do you cancel existing codes?
The codes should be overwritten when you program in a new code.
Aug 09, 2010 | Weiser Lock Powerbolt 1000 Lock
Changing the code
Apr 13, 2010 | Weiser Lock Powerbolt 1000 Lock
I have lost the instructions to program the powerlock by weiser i need a copy of the setup the code where can i obtain this?
Jan 17, 2010 | Weiser Lock Powerbolt 1000 Lock
Center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Jan 22, 2009 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
1,540 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
